Indeed. You need the tubes plugged in to get current through the power rail. Current x Resistance = Voltage droppsaulaferraz wrote: ↑Mon May 21, 2018 6:00 am Hi!
After receiving a new transformer I finally could test the amp! Everything seemed to work fine, but before putting any tubes, I tested the B+ Rails. I discovered that there was almost no difference in voltage between different B+ Rails. Is this normal? I think that it could be because there are no tubes in the circuit and therefore there is no current draw, which following Ohm's Law, will lead me to no voltage drop.
Am I right?
Thanks!
First build: Small Special
Re: First build: Small Special
Yes the dropping resistors don't impact as much as you'd think, until there are tube in circuit. Then the tubes themselves drop current through them, and the dropping resistors have more of an impact too as that voltage drop is based upon how much current flows through them as well.psaulaferraz wrote: ↑Mon May 21, 2018 6:00 am Hi!
Am I right?
Thanks!
