rutledj wrote:I'll go Non-hrm for now and try to figure out the switching later after I have something that works.
Schematic for your feedback
Re: Schematic for your feedback
You'll need to completely revamp everything. Your entire OD section is now wrong, as well as no bright cap on clean master.....
Presence is good now
www.RedPlateAmps.com
Arrrgh!! Apparently there is a way for both of these to live together under one chassis (ala Glasswerks). I guess I need to get the Non-Hrm working then tweak from there.
Rut
Rut
Added ckt around Master clean so when it is switched out it will work properly.
That is only if you remove the clean master load if you are doing seperate masters and nonHRM/HRM with switch. My advice is to chose one circuit or the other. Try the HRM. You can always convert it to non.....
rutledj wrote:Added ckt around Master clean so when it is switched out it will work properly.
