Ryan & Erwin's SSS #002 Madness
Erwin and I are working on bringing the Steel String Singer #002 builds up a notch. Combining his expertise in PCB creation and my chassis/#002 build experience, we're independently working on prototype builds with the eventual release of a DIY chassis + PCB offering to us builders. I also revised my eyelet layout design to accommodate a few optimizations. https://github.com/colganr/steel-string ... er/Circuit
I started a photo album for the progress of my build using a scrap chassis to prove out the PCB design. I'm really, really excited about this and the response has been tremendous so far. I'm confident that the circuit is 98% correct (I would be at 100% if someone with knowledge of #002 or Two Rock Oak Cliff Special can confirm the circuit accuracy, hint hint hint)
https://photos.app.goo.gl/dtXKkZtkknf7buXC8
For this build, I'm using a https://store.mesaboogie.com/products/i ... 390mh.html inductor instead of the SP-118 for comparisons.
Erwin did a fantastic job with the PCB layout and he's refining it based on our experience. No pricing to share yet for the chassis and/or boards, but Erwin will handle the European market and I'll handle the US market.
Before anyone asks, yes, we are also working on getting a schematic confirmed and I encourage you to check out https://github.com/colganr/LTSpiceCircu ... er%20sn002 for the latest corrections. Your feedback is welcomed
Ryan
https://www.thetonegeek.com/
Re: Ryan & Erwin's SSS #002 Madness
This is very cool. I'm into it.
- norburybrook
2 others liked this
Oh dear....... looks like my next build is shaping up.....I hope we're out of lockdown before this hits the streets as I've no work/money....LOL
Great project guys. Really cool to see things like this starting to appear from members, it shows things are moving forwards.
M
M
I'm in too. Probably going to build out a 2x 6l6 35W model using vibrolux transformers I have on hand.
Looks like fun guys and I certainly will look forward to chassis and boards in future thanks.
I totally into a board set, when will you make them available?
Eric
- norburybrook
oooooohhhh
anyone care to hazard a guess as to whether one of these SSS will be significantly different from my Wonderland/JM amp? my wonderland/JM is running 500v on the 6L6 plates and has the switches for all the NFB
M
Guys these boards look great! The USA + Europe synergy is a great idea too!
I wonder if these boards will fit into a 19 in by 8 in chassis for a 2 x 6L6 version ( with re-drilling of the tube locations)
Cheers
Guy.
Cheers
Guy.
Hi Guy,
You have to mount the PT outside of the chassis, otherwise no room. And still then very tight; I'm not sure if thats a good idea
Attached a pic of the boards across my latest ODS build..
Erwin
Thanks for the picture of the boards in your ODS chassis Erwin.
Yes it is tight.
Cheers
G
Yes it is tight.
Cheers
G
Well. The PCBs are CONFIRMED. The scrap-chassis amp sounds just as wonderful as my hand point-to-point! Great job, Erwin, with your PCB design work!
Few notes about the attached pictures. Scrap chassis. Note the front panel switch location is not center, and the tube layout is not perfect inside.
Erwin & I are both having chassis made that are optimized for the PCBs, as well as compatible with the point-to-point layout. Erwin is a little ahead of me for chassis availability (1-3 weeks he predicts). I'm getting an engineering sample next week of a chassis and then it's figuring out silk screening etc. so the US market will be figured out soon and I'll communicate once I get a handle on availability.
Now that the PCB's are confirmed. I'm selling a full set for $150 USD shipped within the US market and Erwin is the equivalent in local currency for the EU market.
Questions are welcomed. Tone demo coming as well although it's technically the same as point to point.
Ryan
I’m so happy I already built the SSS With no time and no space it would have been pain to watch this great stuff floating around me.
To anyone contemplating - the SSS is DA AMP. With this set it’s easier than ever. Go,go,go
Niki
Niki
nice work! I really need to give one of these a go. Looking forward to seeing the chassis
Put me down for a Chassis and board set.
