So I ordered a bunch of stuff from Parts Connexion to try out in my multitude of clones. Resistors from Takman and TKD and a couple of Russian 400pf Silver Mica caps.
Today I installed one of the silver mica's in my Ojai, replacing the CDM yellow 390pf (same as the type on the bright switch). I also tried another yellow silver mica and a nice ceramic 390pf. The Russian cap had way more harmonic quality in a good way and was not as grainy, but loaded with harmonics. The amp fed back much easier with it. I think it may be worthwhile to try these and see what you all think. I also put in a cool looking Takman for the pre OD feed. I added a 4.7K to bring up the measurement to 320 as my trimmer was 96K. Just because I could! The amp does have a binch of vintage resistors and caps, and seasoned Fender 4 ohm iron. It is amazing....
Here is a pic of the cap.
Russian Silver Mica Treble Cap for my Ojai - pic
Artist formerly known as DOGEARS
Re: Russian Silver Mica Treble Cap for my Ojai - pic
Interesting amp
I have never had much luck with Russian caps however, I have not yet tried their ceramics?
I see on the plates you have as 220k's the NTE's what are the 150's (Roederstein's?) I do like the Nichicons on bypass spot and of course the q-line slope..What mid cap is that?..You should try an old Carbon Comp on the 1m input impedance resistor soften's it up a bit IMO.. It's a subtle mod but noticeable
BTW.Have not tried the TDK's but hear good things about them..
- ijedouglas
I don't think Takman or Roederstein. Maybe Philips ECG metal films?
Ian
Not sure, could be Philips. They are vintage. Brandon tried to make this as close as possible to the real 102.
Went back to the traditional silver mica, fwiw.
