I've tried using the search feature, which is actually pretty functional in this forum, but this time I had no luck with results, I believe this might have happened because there is no topic dedicated to this.
Is there any file or information regard the dimensions, even if just the main ones (height, width and depth) of an ODS-50 headcab?
I'd like to start building one, but some dimensions would be handy, just to make sure...
thanks
Dumble ODS-50 headcab dimensions?
Re: Dumble ODS-50 headcab dimensions?
Greetings,
I saw the other day someone (regularly here) posted
Width 527 mm (posted in inches, it should be 20,75 inch, but I calculated it in millimeters)
Height 254 mm (10 inch)
and depth is also around 10 inches (254 mm) or, was it 10,75 inches,
Sven
Sven
Hey Sven, thanks...
