Greetings to all,
Can anyone give me some advise on adding a tube reverb to my Hybrid A build.In particular,which circuit to use and which reverb tank and transformer.I have access to the accutronics tanks and some fender
transformers.
Any help is greatly appreciated.
Cheers
Paddy
Help adding reverb to Hybrid A
Re: Help adding reverb to Hybrid A
Glasman has a schematic posted on his web site for a single 12AX7 reverb. You'd put if just before the PI. Sounds good if you're not looking for Dick Dale surf reverb. It's got a nice rich sound but it's not extreme. To my ears it's just right turned up to about 5.
Hi Bob,
Thanks for the advice,I'll give it a go.Do you have any idea what the value of R10 might be?Also do you think I should use a 12AT7 or AX7?
I'm planning on using the Accutronics 4AB3C1B Tank,any opinions?
Thanks for the help
Cheers
Paddy
Thanks for the help
Cheers
Paddy
That tank would work fine with a standard (Fender) reverb transformer. The input is 2250 ohms and it wants an 8 ohm output load. See this link for reverb tank codes: http://www.ampwares.com/reverb_codes.html
I have used that verb circuit, and it does work nicely. A 12AT7 puts out more power than a 12AX7, so it'll push the xfmr a bit harder for more verb.
Rich Gordon
www.myspace.com/bigboyamplifiers
"The takers get the honey, the givers get the blues." --Robin Trower
That tank's fine. I like the sound of the 12AX7 better, but experiment. The 12AT7 drives teh reverb harder, the 12AX7 has a stronger return gain. In one of my amps I used this circuit but used 2 tubes with parallel triodes. IMHO it doesn't sound better, just a bit deeper.paddy wrote:Hi Bob,
Thanks for the help
Cheers
Paddy
R10 is a dropping resistor. Adjust until you get about 325-350 on the first plate. I used 10K.
Thanks for all the help guys
Cheers
Paddy
Cheers
Paddy
