In my HRM build my fet voltage measures 10V after the 150k dropping resistor. Should I lower the resistor to get more voltage to the fet ? Should I aim for 30V or something ?
Anyone measured the voltage on a real thing ?
fet circuit voltage
Re: fet circuit voltage
10v should be fine. 30v is overkill and not needed.
I've used the circuit in pedal form with 9v battery o.k. but think the original spec of 10-11v provides a sweet boost. I also prefer CCs in this circuit. Yeah I know, I've read all the guff on the net about CCs but they still nicer compared to CF and MF in this circuit to my ears. YMMV.
cheers
cheers
- mdroberts1243
The little FET schematic in the archives calls for 10-11V.mat wrote:In my HRM build my fet voltage measures 10V after the 150k dropping resistor. Should I lower the resistor to get more voltage to the fet ? Should I aim for 30V or something ?
-mark.
My tube blog & link directory: http://tubenexus.com
Cause & Effect Pedals FET Dream and Dumble Style Chassis
Ok, thanks tonelab2.tonelab2 wrote:10v should be fine. 30v is overkill and not needed.
cheers
Ok, then I'm just right thereThe little FET schematic in the archives calls for 10-11V.
btw. mdroberts1243, what schem is that? I can't find that one
mat
Maybe this one:
