I've built a few of these now - original thread here: https://ampgarage.com/forum/viewtopic.php?t=34715
My latest build is having an issue with low output. It won't get much above unity. I have a working one that I can compare things with. I've checked voltages in a bunch of places from my layout/schematic-ish drawing I've made - image attached (red is from working preamp and pencil is from low-output preamp) and they all seem to be very close. I've tried swapping tubes but that didn't do anything. Any ideas what to check?
I'm attaching a picture of my layout/schematic-ish drawing with voltages, a picture of the guts, and the original amp schematic I based it on.
Troubleshooting Low-Output in tube preamp pedal
Re: Troubleshooting Low-Output in tube preamp pedal
things not clear/wrong;
1. voltage on pin 7, -something, must be 0
2. voltage on pin 8, 0.4V, must be over 1.2V
3. what is this in series with pin 6, 22k? doesnt matter too much but why is there?
4. why 1Mohm resistor in series with the output 1M potentiometer, remove it immediately and you will have some gain recovered
layout is difficult to follow, it is not helping to find the problem / in the tone stack circuit=?/
points 1 and 2 must be cleared to proceed.
