New 183 build
- dorrisant
Re: New 183 build
"What's in the box, man?!?"
Seriously, show us you wire organizer. I'm always interested in more ways to do common things.
Didn't mean to derail. Looks very clean so far.
Re: New 183 build
in hi-fi 50w using often Epcos cans 1000uF/300V 2 in series, and all the amps sounds great so i have nothing to say, Epcos is ex Siemens comp.
Re: New 183 build
Cool. I noticed Shad had used the Epcos' after I found them. Basically, I was looking for longevity and a high ripple current. In their position - straight after the rectifier - they have a bit of filtering to do.
I don't know about the Siemens, but I've also used the United Chemi-Con radials with success. They are bigger than the Epcos. [Edit: Er, no! Just compared them again, the Epcos are bigger ] https://cz.mouser.com/ProductDetail/?qs ... fA%3D%3D
Stephen
www.primatone.eu
www.primatone.eu
Re: New 183 build
all of them are 30-35mm so you can design distance between them 36mm and all will fit
Epcoss often are found cheap like for 1-1.5Eur and they are long life, reliable, made for professional electronic, so all is satisfied..
I'm using also UCC often, i bought boxes cheaply
3 others liked this
Re: New 183 build
Another couple of steps forward today with most of the hardware, tone stack, and underboard wiring here...
Stephen
www.primatone.eu
www.primatone.eu
Re: New 183 build
Hi Stephen,
excellent layout of the relay connections, why didn't you use the Tubetown kit as power supply as in the voltage test but did you use a board like Dumble did?
A hug
Franco
A hug
Franco
franco mezzalira
- ijedouglas
Re: New 183 build
Looking really good! You may want to reconsider zip-tying the master in to the OD coax. I used to do it until I had to change out an OD potStephen1966 wrote: ↑Sun Jan 22, 2023 8:21 pm Another couple of steps forward today with most of the hardware, tone stack, and underboard wiring here...
Ian
Re: New 183 build
The tube town power supply is just a bit underpowered for three relays plus 7 LEDs when it only puts out 166mA. The power transformer has a 12V tap which will put out 1.5A which is on the safer side. That and a Dumble board (you see in the pictures) is just more robust. A standard ODS with just two relays and two leds would be okay with it.
Stephen
www.primatone.eu
www.primatone.eu
Re: New 183 build
Good point. Thanksijedouglas wrote: ↑Tue Jan 24, 2023 2:31 pmLooking really good! You may want to reconsider zip-tying the master in to the OD coax. I used to do it until I had to change out an OD potStephen1966 wrote: ↑Sun Jan 22, 2023 8:21 pm Another couple of steps forward today with most of the hardware, tone stack, and underboard wiring here...
Stephen
www.primatone.eu
www.primatone.eu
Re: New 183 build
+1ijedouglas wrote: ↑Tue Jan 24, 2023 2:31 pm Looking really good! You may want to reconsider zip-tying the master in to the OD coax. I used to do it until I had to change out an OD pot
also i dont think wires inside the coax are 100% shielded , maybe better to keep MV out of this group , separated like HAD, to avoid unnecesary coupling..
- dorrisant
Re: New 183 build
bepone wrote: ↑Tue Jan 24, 2023 3:12 pm+1ijedouglas wrote: ↑Tue Jan 24, 2023 2:31 pm Looking really good! You may want to reconsider zip-tying the master in to the OD coax. I used to do it until I had to change out an OD pot
Bepone, I totally believe you but would like to know if you could direct me to pictures that show that.
Re: New 183 build
you can change the OD character of the amp with those cables, at least in my case.. on various dumble amps you can see 2 OD coax bunched, MV separated...i think at least on several pics and different amps i saw this so i thought there can be something
here is 221 from this forum
Re: New 183 build
Thanks! You could be right, though honestly, I have trouble making it out from this photo. I think about the phase relationships and essentially the two coax (from V2a and V2b) could offer negative and positive feedback, respectively. I don't know if it is possible to find to find any shielded cable which can claim to be 100% effective but this stuff I'm using (Belden RG174) claims to have two layers of shielding: 100% coverage, internal aluminium foil (Sorry spellcheck - I'm British!) and, a 90% coverage copper braid over the top. Any emission is likely to be very low.bepone wrote: ↑Tue Jan 24, 2023 5:01 pmyou can change the OD character of the amp with those cables, at least in my case.. on various dumble amps you can see 2 OD coax bunched, MV separated...i think at least on several pics and different amps i saw this so i thought there can be something
Interesting questions I did ask though are why not just use coax for the master? And why not? First, I think, the signal is strong enough to swamp out much of the noise in the sound floor there but I also find it interesting that the master out appears to run in parallel, to and from the FX jacks with the PI in, 0.02uF coupling cap (leading, to what would be V3b, grid pin 7). That seems to me, to be a more likely source of positive feedback and why I abandoned the plan of using coax for the master. If it does exploit positive feedback on the way to the PI, I don't want to mute the effect using shielded cable.
Stephen
www.primatone.eu
www.primatone.eu
Re: New 183 build
If using coax you are killing a lot of heighs.. if not, it is ok.Stephen1966 wrote: ↑Tue Jan 24, 2023 6:37 pm Interesting questions I did ask though are why not just use coax for the master? And why not?
explanation, worst case:
Master volume 1M on low positions , makes cca 900k resistor in series with the mid viper, which is loaded to coax and has capacitance at least 50pF, you have rollof too early, starting after 1kHz. Plus PI input, long tail pair Miller capacitance.
Master should be at cca 250k to avoid this effect, and loaded with some cathode follower to not to load too much previous stage.. I have already tried output from the CF, 100k and 250k Master volume it is working better than 1Mohm
