https://ampgarage.com/forum/viewtopic.php?f=4&t=29845
2nd Gen hybrid
Post by erwin_ve » Sat Jan 28, 2017 5:22 am
EDIT 27 Aug 2023: I finally finished this build and couldn't be happier with the way it turned out. Thanks very much for the comments above that helped finalise the circuit for this build. Here s a video showing the overall build and is filled with sounds from the amp:
I'm planning a 50W Dumble OS style amp build based on some layouts and schematics from this forum. Something along these lines:
- a power section from a 2nd Gen OS style - as per https://ampgarage.com/forum/viewtopic.php?f=5&t=12870 - 2nd Generation Final v2.jpeg - Layout drawing by Tony Albany
- the preamp section, and passive send and return from a #124 OS style - as per https://ampgarage.com/forum/viewtopic.php?f=5&t=5719 - 124_Dumble Overdrive special Complete Layout3.jpg - Layout drawing by Martin Manning & Tony Albany
- adding a presence circuit in the style of the #124 layout drawing that can be switched in or out of the signal chain,
- adding a 'clean blend' control into the overdriven signal in the OD channel. I sometimes like using a y-cable to blend distortion and clean in pedal chains, and if I'm not mistaken the Klon pedal does something along those lines internally, so thinking to try something like it in this build
I'm not an electronics tech or engineer, and have only a basic understanding of circuit design, but have built and modified valve amps and many other guitar related bits and pieces. I've found a lot of answers and information in this forum and others, but have some specific questions in relation to this design and the 'mashup' schematic I've put together and attached, that I was hoping this forum might be able to help with:
- 1). When the presence circuit is switched on (dark blue DPDT switch on the schematic) the current design has a 4.7k NFB resistor (taken from the #124 layout) switched in instead of the 820R NFB resistor (taken from the 2nd Gen layout). Is it necessary for the NFB resistor to be set to 4.7k for this presence circuit to work? Is anything about this design an obvious bad idea, or have the potential to damage anything? My understanding is that there would be less negative feedback (or maybe even none in the milliseconds while the switch is used and changes position), so higher output and load on other components, but I'm pretty keen to just give it a try, but not if it might damage something
- 2). The 'clean blend' idea might be flawed in any number of ways but I'm keen to try it (dark blue items in the OD channel on the schematic). The signal is split prior to the OD trim, and the trim value changed from the recommended 250K to 500K, and there is a new 'clean blend' pot in parallel with the trim (also 500k). The thinking behind that is it hopefully gives the proceeding stage the same load to ground as it would otherwise have had (I have no idea if that is necessary or even actually achieves that though). The clean signal is mixed back into the overdriven signal via a 150k resistor to match the 150k resistor at the end of the OD stage (to act as summing resistors - again I have no idea if that will actually work properly). The question about this is much the same - is there anything about this idea that is obviously wrong or something important that hasn't been considered?
Any answers or tips would be greatly appreciated, but I'll just go nuts and build it anyway and likely post a video of this build with samples to youtube afterwards if anyone is curious to see how it all ends, and what this amp sounds like (whenever that might be).
