JM/Wonderland Contour Pot
Starting on a JM/Wonderland 100 watt amp and have seen some posts about the Contour pot and wanted to see if 250KA or 250KL is better for the Contour pot.
Thanks,
Steve
Thanks,
Steve
Re: JM/Wonderland Contour Pot
I think the sweep is pretty decent with Audio taper however if you want the amp to look brighter, you can go with a linear taper. For example, audio taper at noon position is standard/darker than linear taper at noon position. Adjustments from there.
Ryan
https://www.thetonegeek.com/
Ryan,
Thanks for the reply, great information, will start with the linear pot.
Steve
Steve
Wanted to see if anyone else has had an issue with the contour pots...
I currently have is a 250KA pot, tried the 250KB and both had the same issue, when I turn it past 3, volume drops and sounds gets fizzy.
Thanks,
Steve
Thanks,
Steve
Sounds like you got bigger problems. Contour knob affects negative feedback response , so I assume there is some related oscillation occurring with that part of the circuit . Double check wiring, lead dress , solder joints, ect.Blues Hound wrote: ↑Fri Jun 09, 2023 1:12 am Wanted to see if anyone else has had an issue with the contour pots...
Thanks,
Steve
Charlie
- dorrisant
Without looking... Isn't it similar to a Vox style Cut control?
I have checked wiring, it is correct, reflowed the solder joints, lead dress is good, will post pictures tomorrow.WhopperPlate wrote: ↑Fri Jun 09, 2023 5:25 pmSounds like you got bigger problems. Contour knob affects negative feedback response , so I assume there is some related oscillation occurring with that part of the circuit . Double check wiring, lead dress , solder joints, ect.Blues Hound wrote: ↑Fri Jun 09, 2023 1:12 am Wanted to see if anyone else has had an issue with the contour pots...
Thanks,
Steve
When I use a Dumblelator, there is no issue with the amp.
Here are some pictures.
Took apart and reassembled the .1 caps, 221k resistors and .005 cap and re soldered, still the same fizziness without the Dumblelator, with the Dumblelator in the send/return, Contour works as it should.
Come to think of it , I remember having a similar issue with a JM wonderland when I utilized an electrolytic cap in the negative feedback loop. I just used what I had lying around . I ended up swapping for a film cap and the issue was heavily diminished. I just assumed it was a bad old cap.
Charlie
Thaks for the reply, I will try that today...WhopperPlate wrote: ↑Sun Jun 11, 2023 3:53 pm Come to think of it , I remember having a similar issue with a JM wonderland when I utilized an electrolytic cap in the negative feedback loop. I just used what I had lying around . I ended up swapping for a film cap and the issue was heavily diminished. I just assumed it was a bad old cap.
