Tweedle Dee build
bepone
Tweedle Dee build
Post by bepone »
Here is presented one build with great result, not so strictly following HADs tweaks of 5E3..
My friends build, with little bit help of me..
Build is around this pcb which i have made few years ago..pcb is accepting NFB to cathode of V2..
PT is DIY, OT is Piemme Elektra Italy, some Dralorics CF and SMA metal films here and there, Koa Speer 100k for anodes..First time used 22uF Bipolar caps for cathodes, like in Hi Fi, and Speaker crossovers :lol:
bepone
Re: Tweedle Dee build
Post by bepone »
bepone
Post by bepone »
bepone
Post by bepone »
bepone
Post by bepone »
box pics..
bepone
Post by bepone »
some local find imitation of leather used for the cab.. PVA express glue , side per side, slow process, cable from the old headphones for piping..
bepone
Post by bepone »
now about the sound and tweaking tommorow..
here are clips from finished amp.. there is no tube rectifier, and added NFB, speakers are Jensen C12n, and Jensen Tornado Neodymium,
https://www.youtube.com/watch?v=YnjfHaAxRxE
https://www.youtube.com/watch?v=wMwlGUlDivM
Post by Mark »
Where did you get the circuit board from?
bepone
Post by bepone »
i drew it acc to orig layout and made few pcs..
Post by Mark »
Thanks for your reply, the PCB looks good. I thought it might have been the commercially available PCB’s.
https://www.aaelectronicspcb.com/
bepone
Post by bepone »
only one remained but you are too far? :)
bepone
Post by bepone »
few more pcs:
bepone
Post by bepone »
last state after the tweaks:
bepone
Post by bepone »
Mods/ drifted from HAD:
SS rectifier - with care that voltages are correct
Power tubes screen resistors 470R
Power tubes cathode - 300R
3P NFB switch
Pre PI Master volume (tried trainwreck MV but it was horrible)
Normal channel – coupling cap – 4,7nF
Cathode R - 2,7K
Anode R - 220K
Bypass cap - 0,68uF
Added HI /LO inputs
Bright channel – coupling cap 10nF
Grill vents are to be printed and installed soon
Mattbedrock
Post by Mattbedrock »
Very nice work. Thanks for sharing.
Matt
