Some over two years ago I started an ODS build... for several reasons it went into a halt before last summer, but now it's time to get going again...
I made the larger boards mysellf, with eyelets, and bought a set of the smaller bords from a vendor here.. these were delivered with blank backing boards... Given that even regular PCBs can be quite uneven on the underside - how do you mount these?? Spacers between the two boards, or just screwed together??
PC backing boards
- erwin_ve
Re: PC backing boards
Hi,Aurora wrote: ↑Mon Feb 12, 2024 2:47 pm Some over two years ago I started an ODS build... for several reasons it went into a halt before last summer, but now it's time to get going again...
Backing board has a spacer ideally to prevent stress on traces. I use a nut as spacer.
Erwin
A nylon washer at each mounting bolt is another option, and lets the bolt freely clamp the whole sandwich.
I thought so... just had to ask...
