Question for the Dumble guys?
Will a Dumble/D'Lite 44 fit inside of a small box plexi chassis/headbox? the chassis is a 17X6X3 small box plexi chassis.
- phsyconoodler
Re: Question for the Dumble guys?
You would have no trouble fitting the CIRCUIT inside that chassis,but you will need to get creative where to put the relays and power supply's.I have built the circuit in a very small chassis and had to mount the footswitch relays on the outside of the chassis.The board is smaller than a 2204 but if you use the cap board of the D'Lite it taks up a lot of room inside the chassis,so I would suggest using can caps.Decouple them like marshall did using the D'Lite values and wire it up.
Crystal latice or vacuum,that is the question.
Thanks!phsyconoodler wrote:You would have no trouble fitting the CIRCUIT inside that chassis,but you will need to get creative where to put the relays and power supply's.I have built the circuit in a very small chassis and had to mount the footswitch relays on the outside of the chassis.The board is smaller than a 2204 but if you use the cap board of the D'Lite it taks up a lot of room inside the chassis,so I would suggest using can caps.Decouple them like marshall did using the D'Lite values and wire it up.
