Editable Overdrive Special Faceplate
- boldaslove6789
Re: Editable Overdrive Special Faceplate
This is the final look for my faceplate using the design above but tweaking it for my needs.
Greg D.C.
Can you dig it?
(NEW VIDS here!!) http://www.youtube.com/user/GDClarkProject
http://quinnamp.com/ http://www.prairiewoodguitars.com/
http://www.funkymunkpedals.com/
Can you dig it?
Is it possible that you can make a editable file that will workboldaslove6789 wrote: ↑Sat Mar 12, 2011 12:57 pm Though everybody could use a faceplate that could be modified to their own specific needs, made this last night. Its not exact as far as fonts go but its certainly close enough IMO.
I attached an editable Visio file and the .PDF ready to be printed. The face plate is scaled to 19.25" x 2.5".
You can go to FedEx/Kinco's and have them print it on "Coregated Plastic" for about $15 a faceplate and they're great quality. You can hit'em with some clear coat if you want a bit more glossiness too.
Hope this helps.
To order faceplate /backplate from tubetown
https://www.tube-town.net/cms/?TT_LaserShop/Quickstart
