Moderators: pompeiisneaks , Colossal
Mikka
Posts: 48 Joined: Tue Oct 09, 2007 12:34 am
Post
by Mikka » Wed Jul 18, 2012 9:48 pm
Hi,
I use the freeware Eagle version to try to open the .sch files but it doesn't work.
I have this error message :
Error:
line 1, column 1: Start tag expected.
What is wrong ?
SoundPerf
Posts: 218 Joined: Fri Feb 04, 2011 3:33 am
Post
by SoundPerf » Wed Jul 18, 2012 9:52 pm
Mikka wrote: Hi,
Error:
What is wrong ?
Unfortunately it's not compatible with EAGLE. Even though it shares the same file extension (.sch) it's from a different program.
Chris
Mikka
Post
by Mikka » Thu Jul 19, 2012 4:37 pm
Ok, anyway !
Thanx for your answer.
Anybody has the schematics in jpeg or other currently used extension ?
stiltamp
Posts: 84 Joined: Sun Jun 11, 2006 6:11 pm
Post
by stiltamp » Wed Sep 19, 2012 4:56 pm
@10thTx
Thanks for sharing, great job!
Teleguy61
Posts: 1000 Joined: Sun Mar 07, 2010 7:26 pm
Post
by Teleguy61 » Wed Sep 19, 2012 9:44 pm
Ditto above.
Thanks for your contribution!
Tonegeek
Posts: 882 Joined: Mon Nov 13, 2006 6:23 pm
Post
by Tonegeek » Sun Oct 14, 2012 7:08 pm
This is very useful. Thanks 10th.
10thTx
Posts: 1864 Joined: Sat Dec 30, 2006 1:13 am
Post
by 10thTx » Sat Feb 09, 2013 6:07 pm
This is based on ic-racer's approach to a ManZamp. Note that he has already posted a pdf and visio versions of the schematic and layout that he is using.
http://ampgarage.com/forum/viewtopic.ph ... 389#238389
Ic-racer gave his support to post the editable version so the TAG community can share tweaks and mods around this design. Please NOTE that ic-racer used a different layout design that is discussed in his thread.
CHECK for errors, please! Compare schematic with layout and with ic-racer's schematic and layout.
NOTE :
The original schematic has the first filter cap on the B+ rail exceed the maximum capacitance for a GZ34 . Perhaps use 100uf in series caps instead of 220uf.
with respect, 10thtx
10thTx on Thu Jan 22, 2015 11:39 am, edited 3 times in total.
brewdude
Posts: 652 Joined: Mon Mar 31, 2008 6:26 am
Post
by brewdude » Sat Feb 09, 2013 6:20 pm
Whoa! When I tried to download the MZ layout and schematic here, I got some sort of weird coding.
10thTx
Post
by 10thTx » Sat Feb 09, 2013 7:15 pm
I don't know what to say? They open just fine for me on both my computers? Do you have ExpressSCH program downloaded?
http://www.expresspcb.com/expresspcbhtm ... ftware.htm
With respect, 10thtx
brewdude
Post
by brewdude » Sat Feb 09, 2013 10:46 pm
I have JSchem on my Mac. Perhaps, I need to change the file name from .sch to .jsch?
I was able to open the first one on the other thread, but the other two showed as "The selected Attachment does not exist anymore"...
...Now I can open them, but I get the code text.
I seem to only be able to load it as a web page. I must be doing something wrong.
Chad
Posts: 297 Joined: Thu Jul 21, 2005 3:31 pm
Post
by Chad » Sun Feb 10, 2013 4:52 am
10thTx wrote: Whoa! When I tried to download the MZ layout and schematic here, I got some sort of weird coding.
for the past year or so I have had a diff hard drive and didn't realize I never installed expresspcb on it
everything works fine for me now thanks 10thTx, Chad
sepulchre
Posts: 923 Joined: Mon Dec 28, 2009 1:43 am
Post
by sepulchre » Sun Feb 10, 2013 5:26 am
Hmm. I've definitely got Express PCB on mine - it's all I use. But all I'm getting is text coding. Is there an ExpressPCB update or something?
I've got v7.0.2
sepulchre
Post
by sepulchre » Sun Feb 10, 2013 5:36 am
Okay, if I do the "Save Link As" option it works fine - save a file that opens with ExpressPCB.
Thanks for all the work that went into these!
brewdude
Post
by brewdude » Sun Feb 10, 2013 6:58 am
sepulchre wrote: Okay, if I do the "Save Link As" option it works fine - save a file that opens with ExpressPCB.
Thanks I finally got it to work.
10thTx
Post
by 10thTx » Sun Oct 27, 2013 1:05 pm
From this thread:
http://ampgarage.com/forum/viewtopic.php?t=22722
The build is basically SSS pre - Deluxe OD - Odyssey PI.
Thanks to Aaron Griffin for sharing the schematic.
Compare the SCH version to the one that he posted.
CHECK for ERRORS!
