Carvin X-60A to clone project
Nice size - a little wierd on the tube placement. I hope the transformers produce enough low end definition else I'll use Bassman type.
www.RedPlateAmps.com
Re: Carvin X-60A to clone project
Updated above files - any comments, criticisms etc. welcome. Trying to use terminal strips for the FX loop and Reverb drive but it looks messy to me, should probably try and design an odd shaped eyelet board in that area. Reverb is based on a Prosonic. Thanks to all who have posted stuff in Visio format(and HiGain for the GIFs) - its so easy to use existing stuff as building blocks instead of starting from scratch.
Pix of amp before conversion
Very cool looking project, beautiful layout ! Good luck with this one... I have to find also a donor amp..
What speaker do You have in there ?
mat
It's a Celeston G12-65 (stock Carvin speaker for this amp) but I will probably choose something else after the build is done and I can compare speaker choices using the actual amp.mat wrote:Very cool looking project, beautiful layout ! Good luck with this one... I have to find also a donor amp..
Looks like it will be a sweet sounding good lookin' amp when it's done
Here's a different approach layout, it has holes in the eyelet board for access tp the tubes. I'm feeling adventurous and think I'm going to try this.....
This Amp is now RED!
Test Fit BIP
Finished - This amp makes it debut tonight at a local blues bar - the wires runs and some components were changed for more overtones
Finished pics - clips coming soon - Amp sounded great at the bar.....
Final Schematic
EDIT: corrected FET part of the schematic.
Great looking amp, like Ferrari of the Dumbles Can't wait for the clipsheisthl wrote:Final Schematic
mat
That's so cool it ought to be illegal! I've been tempted a few times to try a similar layout. You may have just put me over the edge!
- glasman
I had a chance to hear that amp yesterday and it is very nice indeed. And SOOOOOOOO tiny.
And FWIW, Henry is a hell of a cook.
Thanks again H2.
Gary
Thanks again H2.
Gary
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
