D'Lite Schematic
Moderators: pompeiisneaks, Structo, mhuss, HeeBGB
mdroberts1243
D'Lite Schematic
Post by mdroberts1243 » Sat Apr 21, 2007 1:49 am
I have seen a few requests for a schematic of the D'Lite... thought I'd give ExpressSCH a try and here is a (draft) schematic of the D'Lite with Relays from Normster's web page (the one I'd like to build someday).
This is just the circuit proper, I haven't done the power supply and shown the relay coil wiring with panel switches... yet (that will be page two and hopefully have room for power scaling.
I'd appreciate any errors pointed out!
UPDATED: I deleted the old, partially complete schematic from this post to avoid confusion with the ones that follow later...
Last edited by mdroberts1243 on Sat Apr 21, 2007 11:15 pm, edited 1 time in total.
-mark.
My tube blog & link directory: http://tubenexus.com
Cause & Effect Pedals FET Dream and Dumble Style Chassis
mdroberts1243
PI plate resistors corrected
Post by mdroberts1243 » Sat Apr 21, 2007 2:33 pm
This has the panel & footswitch wiring and the power supply page.
UPDATED: Minor tweeks and an error corrected... the 2.2K between power C & D changed to 22K.
UPDATED: Corrected relay power supply.
UPDATED: Corrected PI plate resistor values (swapped 82k and 100k around).
UPDATED: Swapped blue & brown to match above.
UPDATED: Changed V1a Ck to 10uf to align with the current D'Lite Layout
Last edited by mdroberts1243 on Sat Sep 08, 2007 10:42 pm, edited 4 times in total.
-mark.
mdroberts1243
Error correction
Post by mdroberts1243 » Sun Apr 22, 2007 11:51 am
I updated the schematics above to correct an error Drew found on the other forum... Power Supply resistor between C & D was 2.2K should've have been 22K.
-mark.
mdroberts1243
Relay Power Supply corrected.
Post by mdroberts1243 » Thu Apr 26, 2007 2:37 am
I corrected the power supply page of the schematic posting... the relay power voltage doubler runs off of the 5V secondary, NOT the center tapped heater secondary.
-mark.
mdroberts1243
CORRECTED PI Plate Resistors
Post by mdroberts1243 » Sun Aug 19, 2007 2:50 pm
I swapped the 82k and 100k plate resistors on the PI.
Thanks to AmpGeek on the Brown-Note Forum for catching this!
-mark.
ampgeek
Re: D'Lite Schematic
Post by ampgeek » Sun Aug 19, 2007 11:08 pm
Thanks alot for this effort Mark. Well done!
But....I can not tell a lie. Dogears pointed out the criss-crossed PI resistors. So...much thanks to him for this and so many other outstanding pointers and suggestions.
Dave O.
mdroberts1243
Post by mdroberts1243 » Sun Aug 19, 2007 11:13 pm
ampgeek wrote:Thanks alot for this effort Mark. Well done!
Dave O.
Well then, thanks for sharing it with all of us that might've stumbled into a pothole on this! That's just as important as finding it.
-mark.
Drumslinger
Post by Drumslinger » Mon Aug 20, 2007 7:11 am
Nice job on the schem mdroberts1243. Thanks!
JazzGuitarGimp
Post by JazzGuitarGimp » Thu Nov 10, 2016 8:09 pm
Can anyone tell me what PT, OT and output tubes are used in this design?
Many thanks,
Lou
Lou Rossi Designs
and Schematic Capture
stelligan
Post by stelligan » Thu Nov 10, 2016 8:42 pm
Some of the early ones used Vibrolux PT and would run 6V6 and 6L6. Some old info here: http://ampgarage.com/forum/viewtopic.php?t=24293
Who is online
Users browsing this forum: No registered users and 1 guest
