Anyone in Phoenix area have a set of Greeley Punches?
Moderators: pompeiisneaks, Structo, mhuss, HeeBGB
markmalin
Post by markmalin » Sun Oct 05, 2014 11:04 pm
Hey guys...before I go buy a set, does anyone in the Phoenix area have a set of chassis punches I could borrow? I need just a couple sizes. If you do and are close, please let me know :)
Mark.
Chandler
"...there are flying v's and then there are the ones shaped like peanuts..." - my son at age 9
Malin Amplification - Boutique Amps
www.facebook.com/MalinAmplification
@MalinAmps
glasman
Re: Anyone in Phoenix area have a set of Greeley Punches?
Post by glasman » Mon Jan 12, 2015 10:42 pm
I just noticed this request.
Live in San Tan Valley and work in Chandler, 202 and 101 area.
About 5 miles south of I-94
www.glaswerks.com
markmalin
Post by markmalin » Wed Jan 14, 2015 3:19 am
glasman wrote:I just noticed this request.
Thanks! I should be good for now - I bought a 1" punch, but at some point may need to use some other sizes :)
Mark.
@MalinAmps
Satchmoeddie-II
Punches
Post by Satchmoeddie-II » Thu Feb 19, 2015 2:35 pm
I am over by the Stack. Like 2 miles north of the state fair grounds. I can pop out most round holes if you mark where you want them. I have 20 or 30 punches from 1/2" up to 4 1/2" and I mean 1/2" not 7/8" for conduit. I also have the big unibits for wowing out the holes in Mojo, Weber and other chassis with 3/4" holes, and you want to use the ceramic 7/8" sockets, or you need to wow out 1" holes to 1 1/8" for the octal sockets. I would rather you mark out a spot and I punch the hole, so if the tool breaks I can blame myself. The keyed 15/32 punch for toggle switches is $320 now. I just broke the cutter, and I have to buy the whole 4 piece set to replace it. It leaves that little keyed tit in the hole so the switch won't rotate in the hole. DB socket punches for computer plugs are $600-$2200 each. Large square punches are $2000 and up. Some of my older smaller punches do not have cross hair hash marks on the dies so it is better just to use the drill press, and a Unibit. By using the hash marks on the cups I can make the holes come out quite straight & very evenly spaced. The drill press has laser cross hairs on it. They are okay, but not perfect. I just redressed the Unibits and they are cutting nicely, if I center punch a starter mark.
markmalin
Re: Punches
Post by markmalin » Thu Feb 19, 2015 3:07 pm
Holy cats!! I'm just south of the 202 in Chandler - if my next chassis comes with the holes slightly off, I may ping you. Thanks!
Do you fab chassis? I need to start getting these locally....
Satchmoeddie-II wrote:I am over by the Stack. Like 2 miles north of the state fair grounds. I can pop out most round holes if you mark where you want them. I have 20 or 30 punches from 1/2" up to 4 1/2" and I mean 1/2" not 7/8" for conduit. I also have the big unibits for wowing out the holes in Mojo, Weber and other chassis with 3/4" holes, and you want to use the ceramic 7/8" sockets, or you need to wow out 1" holes to 1 1/8" for the octal sockets. I would rather you mark out a spot and I punch the hole, so if the tool breaks I can blame myself. The keyed 15/32 punch for toggle switches is $320 now. I just broke the cutter, and I have to buy the whole 4 piece set to replace it. It leaves that little keyed tit in the hole so the switch won't rotate in the hole. DB socket punches for computer plugs are $600-$2200 each. Large square punches are $2000 and up. Some of my older smaller punches do not have cross hair hash marks on the dies so it is better just to use the drill press, and a Unibit. By using the hash marks on the cups I can make the holes come out quite straight & very evenly spaced. The drill press has laser cross hairs on it. They are okay, but not perfect. I just redressed the Unibits and they are cutting nicely, if I center punch a starter mark.
@MalinAmps
glasman
Re: Punches
Post by glasman » Mon Feb 23, 2015 6:29 pm
The guy that does my stuff is near Chandler. Not sure of your volume, but like to work with 100 piece minimums. He can do it all, powder coating, silkscreening, PEM insertion, Aluminum welding.
Just needs a DXF file.
Contact me if you are interested.
Gary
markmalin wrote:Holy cats!! I'm just south of the 202 in Chandler - if my next chassis comes with the holes slightly off, I may ping you. Thanks!
www.glaswerks.com
markmalin
Re: Punches
Post by markmalin » Mon Feb 23, 2015 6:35 pm
Thanks, Gary. My volumes aren't going to be in the 100's for a while yet...but that sounds like a good resource to keep in mind. Thanks!
Mark.
glasman wrote:The guy that does my stuff is near Chandler. Not sure of your volume, but like to work with 100 piece minimums. He can do it all, powder coating, silkscreening, PEM insertion, Aluminum welding.
Gary
@MalinAmps
Who is online
Users browsing this forum: No registered users and 1 guest
