SSS Step filters - Here's what I think
The different versions of the step filters in SSS schematics published here don't seem to make functional sense. Attached is a version (or a correction?) that has a more reasonable and graduated response on the treble side. The key difference is the 0.003 cap going to ground is tied to the treble switch pole, which eliminates excessive treble that results when it is isolated.
Re: SSS Step filters - Here's what I think
Hi Martin, just one question on the filter: What is the function of the 100K to ground. Is it impacting only the treble cut POLE or does it control the gain of the entire filter circuit by leaking signal to ground? What I am interested in understanding is what woud happen for example if one uses higher resistors like 200K or even 300K as ground or lower like 50k
Increasing that resistor will increase the bass.
Thanks Martin. In my case I have it wired as Treble and Bass cut (so the other way around compared to your design). This would then mean that changing the resistor would decrease bass, or it does not really matter?
For some reason I thought it would impact more the high filter than the low
3 others liked this
Some tweaking of resistor and cap values to even out the steps and make the response more symmetrical.
Thanks Martin
Appreciate your time and work
D
D
Thanks Martin! Great work. Just wondering if anyone tested this on a built and how did it compare to the previous?
Hi Martin, is this filter corresponding to the one used on the dumbleland special?
I have found this video on YT and it sound awesome. The filtering seems to really expand the sonic capabilities.
https://youtu.be/zthE05CGFvY
Any schematics of such an amp on ampgarage?
Thanks.
Fred, learning everyday!
Thanks.
Nice demo of the step filters. Notice the full CCW setting of the High filter changes the sound dramatically, killing all the highs. In the circuit above I've tried to eliminate that and even out the effect of the steps. Here's a start on the Dumbleland http://ampgarage.com/forum/viewtopic.php?f=4&t=8043 , but I don't think a complete schematic or layout has been done here. Member dreric is working on a SSS with this revised filter circuit, and an established builder of SSS-type amps has confirmed to me that the relocation of the 0.003u cap to the treble switch pole sounds good.
- dorrisant
Insert "fist-bump" emoji here.
- Colossal
5 others liked this
I built an amp using Martins filters:
http://ampgarage.com/forum/viewtopic.ph ... 88#p380888
Here's the amp demo
https://www.youtube.com/watch?v=snruyEdJN88
https://www.youtube.com/watch?v=O7Auic7wG84&t=17s
Here's the amp demo
Eric
Sounds killer! Great job, all around! That is a real beast of an amp.
Sounds outstanding! Thanks for the demo!
