Add-on tank reverb and loop
heisthl
Post by heisthl »
I am in the process of doing an HRM champ and don't have room for even a 1 tube reverb or loop. I had a 5 x 7 Hammond box and decided to try to build a no compromise tank reverb and loop using a Fender stand alone reverb power transformer and tank transformer. This box will sit vertically against the right rear wall behind the backboard, this leaves room for a short tank on the floor of the amp. 3 tubes, 3 controls and 2 jacks make for some tight design but here's what I came up with - the build is in progress.....
EDIT: updated layout and corrected errors
www.RedPlateAmps.com
tonelab2
Re: Add-on tank reverb and loop
Post by tonelab2 »
Great :D Thanks for sharing. I'm looking forward to building one of these.
You wouldn't a schematic handy, I get a little lost with layouts sometimes.
heisthl
Post by heisthl »
tonelab2 wrote:Great :D Thanks for sharing. I'm looking forward to building one of these.
I built it from memory but I drew this up just for you...
EDIT: added voltages to schematic
tonelab2
Post by tonelab2 »
Thanks heisthl, very much appreciated. Now I can get things sorted. :D
benoit
Post by benoit »
Would this go before the input of the amp?
heisthl
Post by heisthl »
This goes from preamp out to poweramp in. The build I'm working on right now to use with this box has 2 DPDT front panel switches labeled "Reverb" and "FX". These swiches are chained together so when both are off the signal stays in the amp. When both switches are on the preout feeds the loop in and the loop out returns to the amps "Reverb" switch which then routes the signal to the reverb in and the reverb out comes back to the poweramp in. This method puts tank reveb on the FX, but if you wanted reverb first you could switch the connections (the switches would be labeled wrong). I should have this build up and running today or tomorrow and I'll post pictures and status then.
heisthl
Post by heisthl »
pix
tonelab2
Post by tonelab2 »
That's a gem.
jelle
Post by jelle »
That is really nice! :shock: :D
Jelle
Drumslinger
Post by Drumslinger »
heisthl,
excellent little project!! was going through some unread messages and saw this. very nice dude! how is it working out? Just a little behind on past reading.....lol
thyx
re
Post by thyx »
Well don't hold us in suspense...how does it sound?
Guys I think Henry is way too busy to reply his RedPlateAmps are taking off like crazy and sounding fantastic. :)
Phazor
Post by Phazor »
I can Imagine how good it sounds if Henry is building it.
Nice modules to answer any need with tone.
jam-mill
Post by jam-mill »
Built a version similar to the original, but in a little larger box (8"x6").
The larger size box was used to accommodate the addition of the output level pot that is found in the Dumbleator.
Reverb tank used is a 4AB3C1B.
John 15:12-13
jighead81
Post by jighead81 »
Anybody ever find out if this worked or sounded good? Just realized I have enough spare parts laying around to build one.
