The toggles allow you to do things like activate pab automatically when overdrive is engaged or activate fet and bright when clean is engaged.
One caveat is that if you have multiple relays toggled to activate on clean/overdrive, and then you use the stomp switch to activate one of them, it will activate all of the relays that are toggled to switch on clean/overdrive. Think through the layout and you'll understand what I mean.
I built this in a Marshall 5 button footswitch enclosure. I used an 8 pin din connection with one pin left over. I put the toggles on the back of the enclosure... you could also do dip switches internally. I am running a standard dumble style relay supply using an F13X transformer, a 7806 regulator, and five G5V-2-H1 relays.
5 Button Footswitch With Toggles
- Chris Brown
6 others liked this
▶ YouTube: BirdsnakeBrown
▶ Instagram: BirdsnakeBrown
