80's ODS completed
jelle
80's ODS completed
Post by jelle »
Recently I completed a nice sounding 80's ODS with build in Dumbleator. I called it the JWATER :D
Very versatile amp and takes strats very well. This one is a keeper!
jelle
Re: 80's ODS completed
Very nice looking cab and amp. :D
Is that a suede covering?
How about a gut shot or three?
bigmik
Post by bigmik »
very cool looking amp,I'm a sucker for suede.I agree with structo let's see what makes her tick
jelle
Post by jelle »
Yup, Suede. :D
I will make gut shots. Probably this weekend. I gooped it though.
I'm in the process of building a Bluesmaster as well.
Jelle
bigmik
Post by bigmik »
did you play it before and after goop to see if you could hear the difference?
tonelab2
Post by tonelab2 »
Woh... that is real nice. Had to do a double take.
jelle
Post by jelle »
Pics! :D
Before I forget, Sven from this forum helped me with designing of the faceplates.
Jelle
thyx
re
Post by thyx »
jelle wrote: I gooped it though.
Why?
jelle
Post by jelle »
Because it is done. :D
thyx
re
Post by thyx »
jelle wrote:Because it is done. :D
Hmmm...I suppose that means I'll have to goop my SSS when I'm done with it. :wink:
jelle
Re: re
Post by jelle »
hey, it's your SSS when you build it.... The permatex RTV is easy to remove. If you really want to protect your ckt then use epoxy. Please post pics when you are done with it, it sounds like a cool project!:D
For those interested: my ODS is a 100K plate load non-HRM with skyline EQ.
Jelle
erwin_ve
Post by erwin_ve »
Hi Jelle, Nice build! Het ziet er gelikt uit .
Any surprises under the permatex? :wink:
jelle
Post by jelle »
Thanks! :D
No surprises...I did use separate masters on this non HRM.
mat
Post by mat »
jelle wrote:Thanks! :D
Congrats jelle ! Really good looking build ! Btw. what values did You use for the OD master and OD level pots ?
Any chance to hear it with a strat ?
mat
thyx
Re: re
Post by thyx »
jelle wrote: hey, it's your SSS when you build it.... The permatex RTV is easy to remove. If you really want to protect your ckt then use epoxy. Please post pics when you are done with it, it sounds like a cool project!:D
Jelle
Hey...not even sure what an SSS is exactly, so I'm going by what I do know and making up the rest. Sort of "SSS-inspired". I'm quite certain some of the circuit will be unique...but thanks to input from folks on this board, I've got the power amp down to a T, more or less. The filter section will roll off 1/2 dB per step at 82 and 5K. Though I won't build it into this unit, there is provision (circuit-wise) for reverb or an effects loop, or both, without boogering up the filter section. Using a Bassman 100 head-cab and chassis that was completely destroyed (picked up up for a song). Using 5 12AX7s in the pre-amp, with some being cathode-followers (in addition to those post-PI). It'll be 75 watts, though (2 X GE 6550A)...I'm not into tinitus.
Now...back to your regularly scheduled programming...
