80's ODS completed
Re: 80's ODS completed
Mat,
The values of the drive and level pots are 250k and 1M (this level pot has a 250K to ground to mimic a Ratio pot)
I cannot record here.... If you want to hear it you are welcome to come over and play it.
Jelle
Jelle
Thanks jelle for the pot values. I may have to pass Your offer for now. It's about 4123 miles between usjelle wrote:Mat,
Jelle
mat
What is the number for that Silicone is it Permetex?jelle wrote:Because it is done.
The Blue I have seen is darker... gatta have the light blue, it sounds different
I can attest for Purple
The Permatex I used was 80022.
Have fun!
jelle
Have fun!
jelle
I didn't goop my amp, but on my 4x6V6 HRM with Dumbleator and Reverb, I used silicone to stabalize the preamp components, especally the cabs. I'm not sure it's the result, but at the gig tonight I felt the amp was MUCH brighter. It had that added ping on attack that's been missing. It really cuts through well now. The soundman told me he boosted at 250Hz to fill it out a tad.bigmik wrote:did you play it before and after goop to see if you could hear the difference?
I'll add a disclaimer though. I also changed out the speaker jacks which were pretty cheezy, with switchcrafts. That alone can account for the brightness, but I'm sticking to the silicone story.... yep, that it.. silicone.
Until I do this to the next amp and change my mind.
no surprises??jelle wrote:Thanks!
No surprises...I did use separate masters on this non HRM.
u aint foolin me!
jim@Omegaamps.com
Well, the OD can be loud even when the Master is turned downgroovtubin wrote:no surprises??jelle wrote:Thanks!
u aint foolin me!
jim@Omegaamps.com
The clean master is 1M-A and the OD level is 1M-A too.
Thanks! My masters are not balanced at all. Maybe a wiring issue... I think I turn it to single master amp and see what happends.jelle wrote:
mat
Did you check out that RTV wasnt corrosive or an electrical conductor. I have had problems w the cheap stuff w shorting board cameras siliconed onto stainless enclosures.
