Circuit board layout pdf
Moderators: pompeiisneaks, Structo, mhuss, HeeBGB
mlp-mx6
Post by mlp-mx6 » Fri Jan 16, 2009 3:05 am
I don't know if this has been provided yet or not, but here is my approximation of a circuit board (not the power board) for an ODS. It includes a flipped board if you happen to have a chassis designed for tubes-up installation.
The black dots are where the eyelets go. The other holes are described in the doc. The blue grid lines are on 1/4" spacing.
It may not be *exactly* correct, but it is very close. Enjoy!
Me: Just one more...
jaysg
Re: Circuit board layout pdf
Post by jaysg » Fri Jan 16, 2009 6:52 pm
Is it HRM on the board, or non?
mlp-mx6
Post by mlp-mx6 » Fri Jan 16, 2009 9:24 pm
No HRM. This emulates/approximates the Dumble board.
I may do another board that squeezes the HRM into the same board size - but it will tighten up a lot of things.
jaysg
Post by jaysg » Fri Jan 16, 2009 9:58 pm
I think the crammed in HRM is what people want. The Xicon MPPs are small compared to the HAD approved 6PS or PVC orange drops.
Bob-I
Post by Bob-I » Sun Jan 18, 2009 7:57 pm
For this size board you're better off putting the HRM on the daughter board.
Post by Structo » Sun Jan 18, 2009 8:22 pm
When I printed it out at 100% it seems to be smaller than it should be.
I chose no scaling.
Do you know what the length and width is supposed to be on these?
mlp-mx6
Post by mlp-mx6 » Sun Jan 18, 2009 9:35 pm
It is supposed to be 8" by 2.75". Each blue grid line is 1/8".
Post by Structo » Mon Jan 19, 2009 2:49 am
Oh ok, yes that is what it printed out to be, I just thought it looked kind of small.
Which circuit did you base these off of?
mlp-mx6
Post by mlp-mx6 » Mon Jan 19, 2009 1:09 pm
This is supposed to be the "standard" ODS layout - it closely mimics the board I received from Brandon when I ordered the Funk chassis.
ic-racer
Post by ic-racer » Sun Feb 01, 2009 5:26 pm
mlp-mx6
Post by mlp-mx6 » Sun Feb 01, 2009 6:28 pm
Thanks for that.
Is there some problem with scale on the layout I posted? I got it as close as I could to match the board I have in hand.
Post by Structo » Sat Feb 07, 2009 11:30 pm
I have a question on your layout you say the green holes are 1/4".
I don't see any green holes.
Also the corner holes will not leave much material around the hole.
mlp-mx6
Post by mlp-mx6 » Sun Feb 08, 2009 1:46 am
Hey Tom,
I just opened the file and there are 2 green holes in each pattern. Please double-check.
You can move the corner holes in as much as you like.
Michael
Post by Structo » Sun Feb 08, 2009 4:43 pm
Sheesh!
My eyes must be going.
But in my defense they are very faint on my monitor.
Thanx
fenderbender
Post by fenderbender » Tue Sep 08, 2015 2:09 pm
Thank you mlp-mx6, this was very helpful!!!
-Tom
It sounded so sweet... And then it caught fire!
Who is online
Users browsing this forum: No registered users and 1 guest
