Dumb-Lator pcboards please check
hbamp
Post by hbamp »
Did some work today.
Would you please check if they are OK.
Henk
Dutch hand build amps
heisthl
Re: Dumb-Lator pcboards please check
Post by heisthl »
I traced all the way through it and did not find any errors. Good Work.
www.RedPlateAmps.com
dimitris
Post by dimitris »
Very nice, thanks for sharing. One small observation, I remember from a previous post that the higher voltages should go to the cathode follower
heisthl
Post by heisthl »
dimitris wrote:Very nice, thanks for sharing. One small observation, I remember from a previous post that the higher voltages should go to the cathode follower
They way he has it works better :)
dimitris
Post by dimitris »
I'm sure you know better.I will try it this way when I will build mine.Thanks heisthl.
hbamp
Post by hbamp »
heisthl wrote:I traced all the way through it and did not find any errors. Good Work.
Thanks a lot Heisthl,
On my Printer "Samsung CLP-610D" Kodak Premium High Gloss Photo Paper works best. Need some more work to peel off. Result is very
sharp edges. Try some other Brands for the best result on your own Laserprinter. I know Epson Premium worked best on a HP 1100 Monochroom Printer and is easy to peel of.
Henk
erwin_ve
Post by erwin_ve »
Hi Henk<
Looks nice! What's the choice of your transformer?
hbamp
Post by hbamp »
erwin_ve wrote:Hi Henk<
Thanks a lot Erwin,
I use prim. 220/230 V - 30mA -> Sec. 220 V - bridged. 6.3V-1A
They are custom made by Jaspers Transformatoren in Maastricht.
I use them in every Preamp 1 to 3 x 12AX7.
:P kijk in je PM
Henk
hbamp
Post by hbamp »
They are 1 : 1 now!
Henk
mdroberts1243
Post by mdroberts1243 »
Thanks for doing this!
I've been sitting with a bag of parts for a D-lator forever and this spurs the project along.
-mark.
My tube blog & link directory: http://tubenexus.com
Cause & Effect Pedals FET Dream and Dumble Style Chassis
Motörbööt
Post by Motörbööt »
Hi,
thanx a lot!
btw, how must the psu be changed to use a sec. 220V transformer?
hmm, do I see the soldering side? The black pic I mean, cus the green one is the same with the componets on.
Greetz
Very nice work thank you for this.
I haven't done PCB building for years but this I may try.
