M Fowler wrote:Here is a schematic. I had to send this to Jeff Bober about 3 weeks ago he couldn't find it for his magazine article.
Looking at the schemo I see no master volume.
I'm curious if the 50 watt MV is more similar to the 70watt UL or the 50 watt non-MV.
xtian wrote:Look at that "Ground switch", with its associated 0.047 cap, prior to the power tranny. Is that a valid ground switching scheme, or it that one of those "death caps"?
Properly grounded 3 prong AC cords appeared around '71 or '72, but the vestigial ground switch and so called "death cap" remained until the '80s.
On amps that already had a grounded cord I used to just disconnect the switch from the hot side, allowing off-off-cold connection.
This does nothing to protect from badly wired outlets, or the use of an AC ground lift.
Now I just disable the cap altogether and make sure the AC is wired correctly.
reddog
