Amp Chassis Finishes/Colors
StangLX718
Post by StangLX718 »
Hi,
Can anybody explain how Mojave gets there amp chassis this copper color?
http://mojaveampworks.com/amplifier-cra ... omponents/
Is it hammered paint? Or an anodizing process?
Is there any functional benefit to this process/color/finish? Or is it just aesthetics?
Regards,
Stang
RB
Chassis finish
Post by RB »
I bought a few 5E3 Chassis from Clark amplification 3 or 4 years ago that had this finish. I would call the color gold on the chassis I had but I think I have seen the finish in a copper tone. This is a powder coat finish and I don't remember what the call the texture - maybe antique veining or something like that. You should be able to Google powder coat colors and find it.
Regards
Randy
StangLX718
Re: Chassis finish
Thanks,
Is there any functional benefit from power coating a chassis if it's aluminum?
Regards,
Stang
RB wrote:I bought a few 5E3 Chassis from Clark amplification 3 or 4 years ago that had this finish. I would call the color gold on the chassis I had but I think I have seen the finish in a copper tone. This is a powder coat finish and I don't remember what the call the texture - maybe antique veining or something like that. You should be able to Google powder coat colors and find it.
Regards
Randy
Cantplay
Re: Amp Chassis Finishes/Colors
Post by Cantplay »
Rustoleum 7362 copper hammertone paint.
John
ToneMerc
Post by ToneMerc »
Cantplay wrote:Rustoleum 7362 copper hammertone paint.
John
Yes, looks like it. I used the gray color on a SE amp chassis.
TM
chief mushroom cloud
Re: Chassis finish
Post by chief mushroom cloud »
StangLX718 wrote:Is there any functional benefit from power coating a chassis if it's aluminum?
durability and hides fingerprints?
Don't overthink it. Just drink it.
StangLX718
Can you silk screen over that and bypass a faceplate?
RB
Post by RB »
I cant speak to the functionality with any authority. I think time has proven most aluminum chassis do just fine for the most part. If it was a steel chassis powder coat is durable rust protection choice and much cheaper than chrome.
For me the finish speaks more to perception of quality - attention to detail - perceived value - custom built - fit and finish and other marketing oriented issues.
I know the first time i looked inside a Komet amp and saw the chassis and transformer end bells all matching hammertone I was totally impressed.
Two items come to mind than can be problematic:
You should identify all ground points and mask off if you are painting both sides of the chassis(with steel primarily I don't see the need to do both sides with aluminum). Removing the coating to get a good ground is a major hassle and time consuming.
The other item is silkscreen lettering on a textured finish. The texture is very coarse on most of the veined finishes I have seen and would be best to use panels rather than silkscreen. All these issues drive up cost and design/construction/material procurement times.
Regards
Randy
selloutrr
Post by selloutrr »
Once you cover the metal surface it is no longer conductive to the touch. I.e. you have to scrape away the coating to make ground. It's mostly just for looks. And to be different in a flooded market of Marshall and vox knock offs it all comes down to standing out just enough to get your money. Nice amps though.
My Daughter Build Stone Henge
RB
Post by RB »
I have looked at the pics on the Mojave site and the pic that shows the bottom of the chassis with 9 pin socket is clearly a powder coat finish. I have been using hammertone finishes since the early 1960's and You just cant get that depth and type of veining.
Regards
Randy
StangLX718
Thanks Randy!
RB wrote:I have looked at the pics on the Mojave site and the pic that shows the bottom of the chassis with 9 pin socket is clearly a powder coat finish. I have been using hammertone finishes since the early 1960's and You just cant get that depth and type of veining.
Regards
Randy
Powder coating is much more durable than paint.
It is a baked on finish that is very hard.
Once you have to sand some off for a ground point you will know what I mean.
If I had the option between powder coat and paint I would choose powder coat every time.
VacuumVoodoo
Post by VacuumVoodoo »
I've gone all steel & power coat. No more dead trees in my amps!
I didn't know Mojave uses similar copper powder coat (mine is darker) :o
Last edited by VacuumVoodoo on Mon Dec 17, 2012 10:52 pm, edited 2 times in total.
Aleksander Niemand
Life's a party but you get invited only once...
affiliation:TUBEWONDER AMPS
Zagray!-review
Colossal
Post by Colossal »
Very nice Aleksander!
billyz
Post by billyz »
You can also try Alodyne. It actually improves the conductivity and resist corrosion. Very common in the Aircraft industry. But that finish is power coat , you can get a Hammertone like result.
