one tube hot, one not
What does it mean when one power tube gets much cooler than the other?. When I switch the tubes it stays with the socket. One tube is hot as usual, the other I can put my fingers on without it burning like it should. There is no sound coming out of this amp. Its a Blues deville that has been abused, its very rusty. Ive tried good working tubes, same result. Thanks for any help
Re: one tube hot, one not
First off unplug the speaker jack from the bottom of the amp and jump a 9 volt battery across it and if the speaker is good you will hear a good popping / crackle sound as the battery makes connection.
Note, this amp has 2 speaker jacks on its bottom side chassis, and the jack on the left as you face the rear of the amp is the correct one for its internal speakers.
I will assume that when you have a tube in the bad socket that the heater elements glows in the tube atleast, no?
If so proceed to below.
Do these D.C voltage checks with output tubes removed from there sockets.
Pin 3 on each socket should have around 400 volts on it as should the red wire feeding the Output transformer, if the red wire checks for power then the output transfomer is bad.
Pins 4 on each socket should have the same voltage as a good working pin 3, if not then that socket has a bad screen resistor.
Also check that on pin 5 in both sockets you read a minus 48 volts or better, if not do not plug a tube into that socket!
Or he might get the right amount of bias voltage, but have a loose pin clamp on the grid pin (or even a loose screen pin clamp).
Assuming it has the heaters on ,No bias voltage while having plate, screen and a good Cathode connection would have the tube in short order roasting from red plating.
Maybe I'm missing something here. I don't have the amp in front of me. The OP says the problem follows the socket when he swaps tubes. If there is nothing obvious, why not just replace the socket?
Before I replaced the socket, I would:
1) check for continuity on all socket pins; clip on probe to the bottom pin and stick the other probe into the tube end.
2) live circuit check for continuity by taking voltage readings from the top/tube side of the socket instead of the bottom/pin side.
You may find one pin is not adequately tensioned or that its connection from top to bottom is broken.
Screen grid resistor open
Inviato dal mio m3 note utilizzando Tapatalk
