Reverb Driver Voltage Supply
I am wondering which of the 2 options (circled in red under the attached) would be best to add a voltage dropping resistor to the Reverb Driver
1) The one on the left, just next to the Screen Grid supply seems to be the approach Two Rock took on the Matt Schofield amp (although I cannot confirm 100%). Although I would assume an extra 20uF would be needed for this
2) The one on the right between the mixer and PI supply is the one Two Rock used on the John Mayer amp (which I can confirm)
My circuit is most similar to the Schofield (Fender blackface).
Blurry gut shot of Schofield amp here http://ampgarage.com/forum/viewtopic.php?f=4&t=30074
Mayer's amp here: http://ampgarage.com/forum/viewtopic.php?f=4&t=29774
Re: Reverb Driver Voltage Supply
What type of reverb driver tube/stage? (12AX7, 12AT7,12AU7, or some type of tetrode or pentode?)
Then any supply around 400-440ish will be okay. So it'll be fine at the screen node - put the driver tube's circuit returns at the same filter cap ground.
As far as the blackface tremolo (roach) a 22k dropping resistor should be fine?
a 12AX7 will draw ~2mA, so 22k x 2mA = 44V drop. That should tell you where you will land with the HT voltage for the oscillator. Any HT voltage between about 250 and 440 will be ample for getting the oscillator to work.
