New Amp Build
New Amp Build
Here is my new amp build : 100w 4xel34,6x12ax7, 3 channel, high end caps,C-core transformers and point to point wiring.
Biggest challenge was this time to make PTP wiring in small chassis(470x195x60mm).
I am still working on switching, but end result will be with headshell (Italian poplar) only 11.5 kg for full 100w head
Re: New Amp Build
Wow! That's full power OCD, and I salute you!
Re: New Amp Build
That is an impressive piece of work there sir. What do you think of those Jupiter caps? I have yet to try any of those, but I amp curious.
Re: New Amp Build
Nice build. Lundahl transformers are a rare sight in guitar amps.
Re: New Amp Build
Cause they're spendy AF.
Re: New Amp Build
Very nice work! I'd love to see a schematic or just a description of the topology of each of your three channels. Is one of the channels a gain stage added? I'm kinda guessing based on the controls.
Mike
Mike
Re: New Amp Build
I don't have schematic, started from zero. 1-Clean channel ,2-drive channel-First stage parallel-2-3-4-and cf, 3-channel-first parallel-2-3-4 plate driven and different tone stack
Re: New Amp Build
it is very expensive build, free flow build i like that..with all the expensive parts from HiFi collective..IMO maybe no need to go this route, i discovered that some cheap parts works better (EJ parts ) .. been there..
also i never liked exposed terminals on Lundahl , service guy can be electrocuted in a second..
interested to see the results/possible problems..
Re: New Amp Build
Lundahl are there only for weight savingbepone wrote: ↑Thu Dec 14, 2023 11:56 am it is very expensive build, free flow build i like that..with all the expensive parts from HiFi collective..IMO maybe no need to go this route, i discovered that some cheap parts works better (EJ parts ) .. been there..
Re: New Amp Build
and price increase you can use torroids it is the same weight (light) and 5* cheaper (using magnetic flux of 1.5T like here (around) to have low number of turns and smaller core
possible problem in using high saturation core like here /discovered in the past / that attack on the note is very fast, so not good for some types of music..for metal is ok
Re: New Amp Build
I will look into Toroidal, maybe try hybrid rectifier: tube and SS at the same time ?bepone wrote: ↑Thu Dec 14, 2023 12:51 pmand price increase you can use torroids it is the same weight (light) and 5* cheaper (using magnetic flux of 1.5T like here (around) to have low number of turns and smaller core
Sad si mi dao zanimaciju
Re: New Amp Build
Yeah, we have different definitions of expensive.
Re: New Amp Build
When I'm feeling fancy I spring for the 1000v Panasonics. Very nice looking build!
