Deluxe Reverb Build
M3thoms
Deluxe Reverb Build
Post by M3thoms »
Hey gang, I've been messing around with my modded deluxe reverb schematic and I've hit a bit of a snag. I've been referring to schematics of Rivera era fenders, mainly the Deluxe Reverb II and the Concert ii, and effectively combining the schematics so that I can trace my signal path. I am going to input some footswitching capabilities which I haven't drawn yet, but I've hit a bit of a stumbling block. I'm not sure how to connect the FX loop, Reverb and Power section together. I have attached a pdf of my schematic for you guys to look through. There are no component values filled in yet, but I'm wondering if all the wires are in the right place. If not (I'm sure there are a bunch of mistakes this is my first time designing a schematic from scratch) could you point them out to me so that I can fix them. Cheers.
Re: Deluxe Reverb Build
V5A grid needs a resistor to ground.
GAStan
Post by GAStan »
Top of reverb pot is tied to B+, should be to V5b plate and needs a coupling cap.
Where does power for V3 come from?
Presence cap?
V6b output circuit makes no sense.
Screen and grid resistors for power tubes.
What is bottom of level pot feeding V2a tied to? Does this triode need grid resistors?
Glenn
I solder better than I play.
Ten Over
Post by Ten Over »
Here is a straightened-out Concert Series schematic. There isn't really a Concert II, but everybody uses that designation because all of the other ones are "II's".
M3thoms
Post by M3thoms »
Ten Over wrote: Tue Mar 26, 2024 6:21 pm Here is a straightened-out Concert Series schematic. There isn't really a Concert II, but everybody uses that designation because all of the other ones are "II's".
I've just noticed that the FX loop comes after the reverb. Whereas in mine it comes before. What impact is this likely to have?
It's been linked to DPS (double post syndrome). :mrgreen:
M3thoms
Post by M3thoms »
OKAY, so I've spent an evening rejigging the schematic. What do we think now guys?
M3thoms
Post by M3thoms »
Yet again, some more questions on the Rivera Deluxe Reverb style build I've got going on. I've drawn the Vactrol LED's as simple LDR switches on my schematic, the latest version of which I have attached. I have some questions about how footswitching between channels and turning on/off certain functions like the mid-boost would work, and how would I show this functionally on a schematic. I don't really get it and can't find any good resources on the subject online. Also, not sure how to implement a boost function alongside the six position FAT switch as indicated on the schematic. I know I've done it wrong but I don't know how to do it right. Basically, what I want to happen is that I have my preferred rhythm style of mids dialled in with the FAT switch then I hit a footswitchable mid boost for extra gain in solos. So if I have two 0.02uf caps in series, I would be able to switch in an additional third 0.02uf cap in series as well. The theory is something similar to the Custom Audio Amplifiers OD100. Thanks for all your help.
GAStan
Post by GAStan »
The main input and FX input jacks will not work as drawn.
How do you intend to bias the power tubes?
Glenn
M3thoms
Post by M3thoms »
GAStan wrote: Wed Apr 03, 2024 4:34 pm The main input and FX input jacks will not work as drawn.
Yeah I figured haha, was mostly guessing when I drew them. How do these work? What would be the correct way to draw them?
I was going to use fixed bias with resistors.
M3thoms
Post by M3thoms »
Here's the last version, pretty sure I've got this right guys but as always input is always welcome!
What attracts you to this amp?
GAStan
Post by GAStan »
Your last update made my head hurt.
I suggest going back to your original schematic and get it corrected prior to adding mods.
Glenn
M3thoms wrote: Wed Apr 03, 2024 6:28 pm Here's the last version, pretty sure I've got this right guys but as always input is always welcome!
A grid requires a DC path back to its cathode, never leave it floating.
M3thoms
Post by M3thoms »
GAStan wrote: Thu Apr 04, 2024 2:40 am Your last update made my head hurt.
What do you mean 'original schematic'? I'm trying to correct it except I don't know where the problems are, hence the thread
