Matchless Style build
Re: Matchless Style build
I've worked on a couple of Ceriatones and always been impressed with their stuff.
I added power scaling to a customers ceriatone DC30 clone and it was really nicely laid out.
I've never been a big fan of the Matchless way of using tag strip it s a service nightmare!
Ceriatones eyelet boards are much easier. So I dont doubt their Bad Cat clones will be as nice.
Cheers
Shane
Cheers
Shane
Tds chokes are 36h, the vox reissue choke by hammond is 30 i believe,andrew wrote:http://www.parts-express.com/pe/showdet ... _GHIJ_Prod
Sorry to but in but would this choke be acceptable? Hammond 157G
595r 30H 40ma
heres the info i posted on the ceriatone site for transformer specs
575 volt ac ct 600 ma 285-0-285 250MA
6.3 volt 6 amps 5.0 Volt 3 Amps
5.0 volt 5 amps 6.3 Volt 6 Amps
30 watt Choke: T541690
Inductance 36 Henries
30 Watt Output: T541691 Cutout 1¾” x 2¼”
Primary Impedance 4000 ohms
Secondary Impedance 4,18,16 ohms
Build progress....drilled chassis, made face-plates...wiring is up next... pics
Ceriatone Dizzy 30 uses a 10H 150mA choke if your interested.
Thanks Mark
funny the choke I'm using is close to the size of the OT
I may try a smaller one (10-20H) down the road
Darin
not sure why such a large choke(36H) is used in the Bad Cat ampCeriatone Dizzy 30 uses a 10H 150mA choke if your interested.
Darin
dcribbs,
Great looking progress on the amp. I really like the Hot Cat tone, I had a 2004 Hot Cat 30R. I sometimes had some trouble getting the amp dialed in. It was like I would have an unreal tone going for a week, then I would lose it somehow and not be feeling the amp. Then I would find that sweet spot again.
Keep us updated, I can't wait to hear the sound report. This is a build I want on my list.
Faceplates look great!
Amplified Nation
www.amplifiednation.com
@ampnation
@ampnation
Thanks guys
I've not had a lot of experience with the Bat Cat sound
but I know the D style of amps are also hard to dial in that "sweet spot"
I'm hoping this build will allow me to tweak some kind of tone to my liking and I will continue to report progress.
Darin
Darin
Very clean build.
Out of curiosity, where did you source your front and back plates from?
I'm glad it wasn't just me! I had the same experience.amplifiednation wrote:dcribbs,
-g
Thanks WeatheredVery clean build.
I made them from 1/8" or so clear lexan(plastic) used waterslide lables from behind and spay painted...they look decent enough for rock n roll
Darin
I think they look great - I may steal that idea for my new build.dcribbs1412 wrote:Thanks WeatheredVery clean build.
Darin
its a little time consuming but all told
I might have 50.00 in parts and paint and have enough for 4 amps
front and back...I not sure where I got the idea...probably here
was tired of builds with no labels
good luck..let me know if i can help out
Darin
Darin
Darin,
the plates look better than okay for Rock N Roll
Nice looking layout in your amp.
Thanks Markthe plates look better than okay for Rock N Roll
didn't realize how much
having/making face-plates makes a difference to me...
kinda like a pretty face on a nice body...brings it all together
makes me want to build more...
layout is Nik's ...kudo's to him and his guys
Darin
