Conjunctive filter
Re: Conjunctive filter
I reasoned that controlling ringing under abuse/overdrive was where controlling the voltage on the plates was most useful. I stuck in some high voltage transient suppressor/MOV devices. Worked as well as any conjunctive filter I tried. But of course, I may not have encountered a "hard case".
I don't like many amps, and many of those amps I do not like are those with conjunctive filtering.
It can work, but it isn't magic in and of itself.The ones I tried were big sand resistors and 1600V caps.
Record hand noise on the strings. Look at the ugly peak of fingerprints on course wound strings. Make a low-pass filter with that frequency starting lowest just above the knee. Look for a decent place for it after a master on the way to the PI. Even better, use two smaller circuits with one on the last driven stage and the other at the PI.
In RDH4, Smith provides some examples. You might find that helpful in combination with some of the concepts teemuk was explaining.
Here is a screenshot of page 588.
Thanks!SoulFetish wrote: ↑Sat Dec 09, 2023 2:53 pm In RDH4, Smith provides some examples. You might find that helpful in combination with some of the concepts teemuk was explaining.
Screenshot 2023-12-09 at 09-46-24 Radiotron Designer's Handbook 4th Edition - rdh4.pdf.png
