Is there any simple 4 channel Latching Circuit?
Gainzilla
Re: Is there any simple 4 channel Latching Circuit?
Post by Gainzilla »
Posted to the PCB forum on this site: https://ampgarage.com/forum/viewtopic.php?f=17&t=31438
There is a full Gerber file you can download. Upload it at jlcpcb.com, and for like $20 you can get 5 PCB's made. Buy the parts to populate the board, and for good Karma, maybe offer the remaining boards to other members here for the cost of postage.
I've used this circuit, and it's very simple and easy to use.
Bryce
I know it's only rock and roll, but I like it!
dorrisant
Post by dorrisant »
Gainzilla wrote: Tue Jun 27, 2023 12:28 am Posted to the PCB forum on this site: https://ampgarage.com/forum/viewtopic.php?f=17&t=31438
Bryce
Good idea... Do you have a copy of the instructions? That particular link seems dead... https://ampgarage.com/forum/viewtopic.p ... b5#p389251
Maybe Lauri will show up and help out...
Gainzilla
Post by Gainzilla »
Here are a few things that may help. Updated link for the originally posted one: https://sound-au.com/project163.htm
Re: voltage (From Lauri): Maximum recommended supply voltage for 40175 is 15V. V+ can be anything from 5V to 15V
From my project notes:
  • GND - All grounds connect to the same trace
  • V+ - All V+ connections are the same trace
  • CTRL 1-4 - Connects to Relay coil anode (-)
  • V+ and GND nearest the IC are the main connections to power and ground
  • D1-4 connect to one side of each momentary switch
  • V+ - near each corner, connect to the other side of each momentary switch
  • D6-9 - connect to each channel’s LED indicator
BOM
  • R1 - 10k
  • R2 - 10k
  • R3 - 10k
  • R4 - 10k
  • R5 - 10k
  • R6 - *
  • R7 - *
  • R8 - *
  • R9 - *
  • C1 - 10n
  • C2 - 100n
  • D1 - 1N4148
  • D2 - 1N4148
  • D3 - 1N4148
  • D4 - 1N4148
  • Q1 - BC547 (or 2N7000, but reverse the orientation. Pinout is opposite)
  • Q2 - BC547
  • Q3 - BC547
  • Q4 - BC547
  • U1 - 40175
LED Resistor Values
https://www.allaboutcircuits.com/tools/ ... alculator/
5V (for use with 5V relays)
  • Red - 150 Ω
  • Green - 145 Ω
  • Blue - 70 Ω
  • Yellow - 145 Ω
  • Orange - 140 Ω
  • White - 70 Ω
  • UV - 165 Ω
12V (for use with 12V relays)
  • Red - 500 Ω
  • Green - 495 Ω
  • Blue - 420 Ω
  • Yellow - 495 Ω
  • Orange - 490 Ω
  • White - 420 Ω
  • UV - 515 Ω
Gainzilla
Post by Gainzilla »
I've got a 3 channel build in the works. I'll try and get some pics.
dorrisant
Post by dorrisant »
Awesome... Thanks!!
