The currents through the EF86 look credible, so no worries there.xtian wrote: Higher plate voltage now: 158v, but still reading zero at pins 1,8. So weird.
I'm using 10K in place of the 8K2 dropping resistor. So, 9.2v dropped across this resistor gives me 0.92mA. Can that be right?
Also, 169v drop across the 220K plate resistor gives me 0.77mA.
That's stupid. It should be eating a few milliamps, right? Maybe I should take the next step toward the Vox design and change the cathode resistor to 1K5. What do you think?
The real puzzle is why you're not seeing a volt, or so between pins [EDIT] 3/8 [/EDIT]& ground.
Give the 1k5 a try ....I have played around with an EF86 as 2nd stage, and it is interesting to see/hear the effect of changes. The worst thing that happens is that you drive it into cut-off, because then it sounds like XXXt. To guard against this, you need to bias it on the warm side of centre and arrange the preceding stage to compress the signal on peaks. The screen voltage also needs to be pretty low IMHO. When you get it all right, it sounds superb. Don't be afraid to put a big grid stopper on the EF86 (even up to 560K) - it doesn't knock off the highs like it does with 12AX7s as the Miller effect is much less, but it can really smooth out the odd harsh transient if you push it hard.
Experiment!
