half marshall 100 watt cutting out
tweedydum
Post by tweedydum »
hi,
a friend is bringing over his marshall stack tomorrow. Apparently, it has gone to half volume at least once. He thinks the tubes stop glowing when this occurs.
I thought I would start by chopsticking all board/tube/output txfm connections and hope that something is loose.
Any other suggestions?
thanks,
Dave
dobbhill
Re: half marshall 100 watt cutting out
Post by dobbhill »
clean/re-tension sockets...
D
In a tube amp the first suspects should always be the tubes.
How long since he replaced the power tubes?
Since you mention half power, check the power tubes.
They have a finite life span.
The V2 tube gets hammered pretty hard in Marshalls as well.
So always check the tubes first. Take a known good tube and substitute it for each preamp tube.
If that doesn't fix it, then on to the power tubes.
selloutrr
Post by selloutrr »
i've had this a few times both were preamp related.
My Daughter Build Stone Henge
