PT CT light bulb to ground
Andy Le Blanc
Post by Andy Le Blanc »
Been noodling on the bench, and I just couldn't resist.
The amp I'm fiddling with uses generic 50W fender replacement trans..
There's been quite a bit on the forum with vvr and other ways to drop the
B+ supply to power tubes, zener strings, and light bulbs.
So I tried lifting the CT of the PT and dressed it through a standard medium
light socket and fired up the amp to "see" and "hear" what happens.
100w bulb; amp ran fine, measured around 4v ac at the ct, slight drop in the
supply V DC..... The bulb eventually got warm, there was thermal noise
from the bulb as it barely heated.
60w bulb; amp again ran fine, measured around 18v ac at the ct, slightly more
drop in the supply V DC.... the bulb light faintly, heated, no noise
The 60w changed the presentation of the amp, in a nice way, still had the
power but the tone color was different, It was a surprise, there might be something to it.
I've read about other "bulb" applications, they are utilized as a CCS or a
constant current source, it seems to be valid approach even for a guitar amp.
There is a usable voltage drop and a degree of current regulation.
I'll try a few different wattage's too and see about the V drop at the ct.
lazymaryamps
Re: PT CT light bulb to ground
What was that amp we talked about recently that used the light bulbs for attenuation/ scaling?
Seems it had several for different amounts of attenuation.
Andy Le Blanc
Oh geez..... wasn't that far back. About "Samamp".
A single 15w all most fully lit, 98vac at ct, really quiet, the tone suffered.
A single 25w half lit maybe, 68vac at ct, 10th or 8th the power still usable
tone and response.
A half dozen bulbs sockets and switches, parrallel connected between the ct,
and ground, just add or remove a given number of bulbs for the attenuation,
seems to work.
lazymaryamps
Andy Le Blanc
light bulbs seem to work as power attenuator, simple vvr.
I still need to gig one out to know, it sounds good in the shop.
So .... anybody got an idea to chassis mount a socket
lazymaryamps
Jana
Post by Jana »
I'm thinking one or more of those old style porcelain light bulb sockets--a real Uncle Fester creation. For full visual effect you should probably use one of those triode tubes with the anode (?) that clips onto the top of the tube like a spark plug would. A row of knife switches to select which bulb(s) are in the circuit would be a nice touch.
CapnCrunch
Post by CapnCrunch »
Hey Andy,
After you put Jana's suggested contraption together, you should dress up like Doc from back to the future. Video your gig and post it here :D It would awesome!
Wayne
Post by Wayne »
Andy Le Blanc wrote:light bulbs seem to work as power attenuator, simple vvr.
Just drill the hole a little bigger to accommodate your larger "pilot light" - everything should work out just fine :D
W
Andy Le Blanc
That's a hoot :lol:
be careful of what you wish for.
The BIGGEST tube I have is a light bulb from a search light or architectural illumination,
110 V...... doesn't sound impressive yet, right?
check it out.... guess the watts.
lazymaryamps
FunkyE9th
Post by FunkyE9th »
I think you need to get one of those bathroom light fixtures with a built fan, you get attenuation and cooling, all in one. :)
Whoa!
That is cool!
Is that a metal halide light bulb?
Check out the screen grid on that bad boy! :D
Andy Le Blanc
It's a GE G96 120v 10K w, and as far as I can tell its just a big light bulb.
It has temperature stamp on it 3350 k, crazy....
lazymaryamps
Wayne
Post by Wayne »
We've got 120V 1000W halogens here at work but hands down, you win the prize!
I wonder if 3350 K refers to the color. Isn't lighting color measured in Kelvins?
W
Lonely Raven
Post by Lonely Raven »
Wayne wrote:We've got 120V 1000W halogens here at work but hands down, you win the prize!
W
3350k would probably be the color temperature. That would be a very warm yellow.
Jack of all Trades,
Master of None
selloutrr
Post by selloutrr »
My Daughter Build Stone Henge
angelodp
3200k is normal
Post by angelodp »
3200k is a 'normal' light bulb color temp. Thats right Kelvin. Its all relative to what you record the light on, but a camera that has a symbol for 3200k.. a light bulb.... will see that 3350k as slightly cool, compared to the 3200k.
Warm ( yellow-orangy ) would be 2800k.
Daylight is 5500k - average.
Cheers A
