6AK6 push-pull output transformers
BT123
Re: 6AK6 push-pull output transformers
Post by BT123 »
Can anyone tell which blackface circuit this amp is based on? Just curious.
tube geek
s2 amp
Post by tube geek »
BT123,
The preamp looks like the typical Fender style found in the non-reverb models
like the Deluxe. The phase inverter is more like the Brown face series, and the output stage is similar to a tweed class a cathode biased amp. I am guessing that there are also midrange and presence controls involved.I hope that helps.
BT123
Post by BT123 »
It sure does. Thanks!
BT123
Post by BT123 »
Here's another S2 Mico Amp. This one is the M4 which is the SLO 100 copy.
This particular amp has the upgraded Mercury transformers. You can see the 4,8,16 ohm selector on the rear.
[img:700:525]http://i195.photobucket.com/albums/z235 ... d60147.jpg[/img]
[img:700:525]http://i195.photobucket.com/albums/z235 ... 439992.jpg[/img]
