Chassis purchase
Chassis purchase
I have been wanting to build a Fender 5E5A. My only real hold up is the chassis. I have never had to buy a chassis before. I need one that is all drilled and punched.
Mojo has them for $60.00 plus shipping. Nik (Ceriatone) has them for 50, but that will obviously be more for shipping. Do any of you guys build/supply chassis' that are all set up, or should I just get one from Mojo..?
I do not care if it is period correct, just need it to accommodate the 5E5 circuit.
Thank You
Thank You
Re: Chassis purchase
Get onto RJ - rjguitars.net - his chassis are well made, and he should have one available with 3 novals, and 3 octals as a 5E5 would use.
__________________________________________
Cheers and Beers.
Cheers and Beers.
I've used the project chassis from Allen Amplification and have been very satisfied with it. Heavy duty construction and predrilled. Reasonable prices for Fender style angled front chassis. http://allenamps.com/minichassis.php
I always forget about Allen, when it comes to parts.tkdrew wrote:I've used the project chassis from Allen Amplification and have been very satisfied with it. Heavy duty construction and predrilled. Reasonable prices for Fender style angled front chassis. http://allenamps.com/minichassis.php
Have you ever played a Pro?
I have thought about that amp before as well.
Are you going to leave the input configuration stock or cascade the first two stages?
I see Weber wants $90 for theirs.
They have chrome or glossy chocolate.
https://taweber.powweb.com/store/chassis/chord2.html
Hey Structo -Structo wrote:Have you ever played a Pro?
I did not realize what a crazy schematic (for a Fender in my experience) this was. Did Fender use a cat follow very often..? I was just going to build it per the original schem. Are you talking about trying to get more gain out of the amp..?
You are right about the Weber chassis. It will be 30 dollars cheaper if I get one from Mojo. I wish I could see a Ceriatone chassis for comparison. Like I said, "period correct" does not matter to me. I read a lot of negative stuff about Nik's products (especially on the gear page) I would really like to see his chassis next to a Mojo.
Thank You
http://www.el34world.com/charts/Schemat ... _schem.pdf
Tweed Super (2x10) 5F4, tweed Bandmaster (3x10) 5E7, tweed Bassman (4x10) 5F6-A, Twin (2x12) 5F8-A... all the good stuff of the era.hired hand wrote:I did not realize what a crazy schematic (for a Fender in my experience) this was. Did Fender use a cat follow very often..?
Here's one DIYers take on the circuit ( its a 5E7 Bandmaster, but that's the same circuit as the 5E5A Pro ) with the stages cascaded : http://www.kilback.net/homebrewtweaks/a ... m#tweed5e7
Gotcha...this is my first real experience with a Tweed.Zippy wrote:Tweed Super (2x10) 5F4, tweed Bandmaster (3x10) 5E7, tweed Bassman (4x10) 5F6-A, Twin (2x12) 5F8-A... all the good stuff of the era.hired hand wrote:I did not realize what a crazy schematic (for a Fender in my experience) this was. Did Fender use a cat follow very often..?
http://www.el34world.com/charts/Schemat ... g_B25B.pdf
I think I made a mistake. I was planning on using the tranny set from this old Ampeg. But the Fender specs a 5U4, and those things want 3 amps for the heaters. Not sure if the Ampeg PT will put up with that. I guess if the plate voltage is acceptable, couldn't I use any rectifier I want..?
Hey thanks, that looks like a great amp.KT66 wrote:Here's one DIYers take on the circuit ( its a 5E7 Bandmaster, but that's the same circuit as the 5E5A Pro ) with the stages cascaded : http://www.kilback.net/homebrewtweaks/a ... m#tweed5e7
My next will be a grab and go combo so Tweed plus some overdrive sounds appetizing.
