need a new DVM
- Luthierwnc
need a new DVM
Hi All,
It is time for a replacement. Any opinions in the "inexpensive but works well" category? Thanks, sh
dvm
I recommend the not so inexpensive fluke 179. You pay for it up front but it's the last one you'll ever need.
Does everything well, easy to use and read.
I don't have the time to deal with inaccurate or unreliable test gear.
Anyway, I've used fluke meters for 30 years and have never been disappointed. Having said this, everyone has different requirements and your budget has the final say.
This opinion and $7.95 will get you a latte at starbucks...best, Mark H
Re: need a new DVM
Sorry It's FLUKE or nothing.
Buy right and it'll out last you.
Try craigslist in your area you might be able to pick one up used.
Fluke offers calibration and service for a small fee.
My Daughter Build Stone Henge
Re: need a new DVM
I think you just got some really good advice on the Fluke.
I had a Triplett 9045 http://www.amazon.com/Triplett-9045-Mul ... B001ULFROW that I really liked, but it died on me finally when I accidentally misused it. It is a very nice meter and it will set you back $60-$90 depending on your luck in finding a discount. For not very much more, you can get a Fluke.
If your needs a basic, you might consider haunting eBay for an older Fluke bench meter that does all the basic stuff well. I've got one that I paid about $20 for. Be careful, though. What I didn't understand is that the ones with the battery "option" don't work without the batteries. Right away, I had to spring for 4 NiCd cells, which put the price of that meter closer to $40.
The point is, there is no free lunch. Bite the bullet and get the Fluke, or go low end and hope it lasts a while. Don't get something in the middle price wise because it is the worst of both worlds -- not a Fluke, but you put too much money into the purchase to give it up.
IMO, all cheap meters are in the same class, so it doesn't matter much which one you pick. I didn't want to believe that, but it's where I ended up in my thinking.
Re: need a new DVM
- Luthierwnc
Re: need a new DVM
Thanks guys, I had a nice Fluke once but I incinerated it installing an electric fence. I'll keep my eyes open, Skip
Re: need a new DVM
NOT.... They wanted close to $300 to repair and calibrate my 87 meter.selloutrr wrote:
They make a great meter, as I have owned 3 for nearly 25 years. I don't think you could go wrong by buying one.
I Think I Think Too Much !
Re: need a new DVM
I have a B&K meter that you can get the new version for around $60 - 70. It has capacitance up to 20uF and transistor testing (which is why I bought mine years ago)
I have been happy with it.
Re: need a new DVM
You must not be very nice on the phone.. lolDr-Joned wrote:NOT.... They wanted close to $300 to repair and calibrate my 87 meter.selloutrr wrote:
I just had my 827B calibrated and serviced for $100 after shipping.
last October I sent in a 77 I don't remember it being over $50.
Re: need a new DVM
I've never seen a Fluke that was actually out of calibration enough to where it would matter with what we use them for in amps.Dr-Joned wrote:NOT.... They wanted close to $300 to repair and calibrate my 87 meter.selloutrr wrote:
Re: need a new DVM
I use mine for studio repairs, matching components, amperage reading, and current draw recording. As well as whatever else needs a meter. The 827B is over kill to start with, I like keeping my equipment running properly. It makes troubleshooting easier when you know your equipment isn't the problem.
It's true you could probably buy it once and never need to calibrate it for basic metering and continuity testing.
Re: need a new DVM
Oh I mean calibration is good for extreme precision. We do a lot of in house calibration at my job, and we have all sorts of equipment to test calibration. We have never found a fluke that was out of calibration so much that it would matter. I have never seen one off more than .5%, which is fairly good for just about anything.selloutrr wrote:I use mine for studio repairs, matching components, amperage reading, and current draw recording. As well as whatever else needs a meter. The 827B is over kill to start with, I like keeping my equipment running properly. It makes troubleshooting easier when you know your equipment isn't the problem.
Only time my fluke doesn't work is when I pop the current fuse.
Re: need a new DVM
I have a few Fluke 8012A's that I bought off eBay a few years ago. They are all rock solid and can be had cheaply. I generally stack two or three so I never have to change functions. They are not new but basically bullet proof.
http://shop.ebay.com/i.html?_nkw=Fluke+ ... m270.l1313
Re: need a new DVM
http://www.hmcelectronics.com/Test-Equi ... timeters/2
http://www.amazon.com/s/ref=nb_sb_noss? ... &x=13&y=12
The Amprobe 35XP is a well made meter. 2 amps is plenty for the inside of a guitar amp.
Best
Best
