anyone use an IEC socket with integrated fuse? PN needed
wsaraceni
Post by wsaraceni »
Looking for part number. I am building something else with a trainwreck express chassis. I want to add a 2nd fuse for the build, and i also want to get rid of the attached power cord. So i figure i can put the mains fuse in the IEC socket
Re: anyone use an IEC socket with integrated fuse? PN needed
Hoffman carries them.
There should be multiple places that carry similar.
They usually use a 5mm fuse.
[img:900:567]http://www.hoffmanamps.com/MyStore/cata ... G_2343.jpg[/img]
da Geezer
Post by da Geezer »
Here's the one I use. Uses 5x20 fuses & has storage for an extra/spare in the drawer.
http://www.mouser.com/ProductDetail/Sch ... B16w%3d%3d
(look on page 1325 of mouser cat http://www.mouser.com/catalog/catalogUSD/645/1325.pdf )
I prefer the screw mounted (wings) type, but they also have snap-in type if you like.
That one has solder tabs, but you can get quick connect style also.....just look @ the specs/pictures on pg 1325.
HTH, Geezer
edit: Tom has it right.....didn't realize Hoffman had started carrying them. Order it along with all your other build stuff from Hoffman & you're set!
wsaraceni
Post by wsaraceni »
thanks guys. for some reason i had a brain fart. i kept seeing 250v thinking i needed to find a 120v version. not realizing that its up to 250v that i had to work with.
i assume i need to use the 120v fuse though, even though it says use a 250v fuse.
Thanks Geezer,
I tried looking at Mouser but as usually I couldn't drill it down due to the filters.
Phil_S
Post by Phil_S »
$0.99 at Apex Jr. Comes with the wrong value fuse, but that's can be changed quick enough. What do you want for a buck?
http://www.apexjr.com/FuseHolders.htm
paulster
Post by paulster »
wsaraceni wrote:i assume i need to use the 120v fuse though, even though it says use a 250v fuse.
No, the current rating, rupture time (quick-blow, slow-blow, etc.) and physical size is all you are interested in. Fuses will generally be rated at 250V since this allows the same fuse to be sold in all markets. Same as the IEC inlets.
wsaraceni
Post by wsaraceni »
great. only amp i've built was a kit so i never had to research that stuff. this time i'll definitely be trying to size the right size fuse. and adding a HT fuse as well
LeftyStrat
Post by LeftyStrat »
Has anyone tried the circuit breakers that Weber sells? Seems like it would be safer, since some guy wouldn't be sticking the wrong value in (or worse, a gum wrapper).
Bottom of page:
https://taweber.powweb.com/store/fuseord.htm
The description is a little light on details.
Phil_S
Post by Phil_S »
I bought a couple. Then, someone explained to me that the trip load is somehow different from a fuse and they aren't so well suited to tube guitar amps. I forget the whole explanation, but I removed them. My take on it is that they should be OK in place of the mains fuse on the AC side, but are not appropriate for fusing DC, like the HT center tap.
davent
Post by davent »
I order most stuff from Digikey so use a Qualtek unit from them. (Canadian prices).
http://www.digikey.ca/scripts/DkSearch/ ... ds=q201-nd
collinsamps
Post by collinsamps »
LeftyStrat wrote:Has anyone tried the circuit breakers that Weber sells? Seems like it would be safer, since some guy wouldn't be sticking the wrong value in (or worse, a gum wrapper).
Bottom of page:
I have and I wouldn't recommend them to anyone. Extremely low quality, the reset switch might handle 10 resets before it's toast. I built some CB alligator clips to place across the fuse receptacle for troubleshooting shorts using them in 2 & 3 amp, and they all failed eventually.
milkyBK370
Post by milkyBK370 »
I have used these a couple of times. I got mine from Ampmaker in the UK.
pablogt
Post by pablogt »
I'm using the ones from Apex Jr. too.
Pablo[/quote]
wsaraceni
Post by wsaraceni »
got them here. now to figure out the best way to cut the hole. i guess the dremel might be the ticket
