Rustling noise help
Rustling noise help
Have a '67 Super Reverb. Plugged it in for the first time in about 5 months. There is a constant rustling noise, kind of a static/rustling that is happening regardless of having a cord plugged in. The volume knob has no effect. It's just constant with the amp on. Any suggestions on where to look first?
Re: Rustling noise help
First I would clean the sockets then try swapping preamp tubes if that dont work then I would be looking at plate resistors
Have the electrolytic caps been replaced? My early super reverb did this before I changed out the power caps.
Yes, I changed all electrolytic caps less than two years ago.mhartman wrote:Have the electrolytic caps been replaced? My early super reverb did this before I changed out the power caps.
I cleaned all sockets with deoxit. No improvement. Will swap preamp tubes tomorrow, and see if that does the trick. I changed all plate resistors to get everything in spec just before I stopped playing it this summer. It was fine then. Maybe a bad solder joint. I hope not.cbass wrote:First I would clean the sockets then try swapping preamp tubes if that dont work then I would be looking at plate resistors
One time I had this problem and it was a pain running it down.. until I noticed my cattle were missing.
-wapppssshhhh!-
-wapppssshhhh!-
(deleted)
Hi Bluesguitar,
my guess, the problem is probably to be found in a cold/bad solderjoint.
As you mentioned you've replaced some electrolytic caps. Well, I would start resoldering that components.
Succes.
grtz
Guss
Succes.
grtz
Guss
I've experienced that type of noise with a bad preamp tube before.
- Milkmansound
unfortunately thats the "something is wrong" sound that can be one of many simple things:
I have seen a bad 12AT7 reverb driver do it
a noisy preamp tube
bad solder joint somewhere
preamp tube plate load resistor
preamp tube cathode resistor
fractured lead on a capacitor
conductive circuit board
lead dress
etc...
a noisy preamp tube
lead dress
etc...
Update: I've swapped each preamp tube one at a time to try to isolate a bad one. No change. I pulled the reverb and tremolo plugs, deoxed them and reseated. No change. Going to have to troubleshoot the chassis. Pain in the ___! I appreciate all of the suggestions, but too much humidity just doesn't make sense to me. Why? Ever heard of Nashville? Think they have much humidity? Think they've ever stored a fender amp in a warehouse or studio with no air conditioning for a year or two between use. Just sayin.matt h wrote:Bizarre/not so bizarre suggestions--
if you've tried reseating all the power tubes, ALSO do this with all plugs/sockets. I've had issues where reverb cables needed a little twist/reseat action.
If that doesn't help, er, looks like the humditty done did gotcher carbon comp plate resistors and/or you've got some bizarre RF interference.
Fairly well documented phenomenon.
http://www.guitarplayer.com/article/sho ... games/7179
Google will show many more hits if you were to search for: fender conductive board.
Good luck!
jelle
Good luck!
jelle
Thanks for the link. I've browsed a few articles, but I don't think this is the problem. The articles mention symptoms of poor tone and scratchy pots. The tone of my amp is fine, and I don't have scratchy pots. In fact, nothing I do affects the constant (low volume) rustling/static. Its just there as soon as I take my amp off standby. I can play above it with some volume, but it's loud enough that it is more than just normal hum.jelle wrote:Fairly well documented phenomenon.
Good luck!
jelle
The only way to know is to measure it.bluesguitar wrote:I don't think this is the problem.
Good luck!
jelle
