Is.It possible to.Adjustable cathode bias, it's for a pair 6v6
I'd like to be able to adjust between 400and 480 ohms [/quote]
Adjustable cathiodbiae
Re: Adjustable cathiodbiae
Hi, Mark...are you trying to type with your toes? Nice job!
Using a switch would be easy. But maybe you are asking about using a pot or rheostat to adjust the cathode resistor value?
I use 2 470ohm resistors + 2 100ohm pots on a pair of 6v6s to do this. Pots are 5wt wire wound. Each has its own bypass cap.
Since you are going thru the added effort to set things up this way you may as well give yourself 100% control and install a seperate resistor and bypass cap for each tube plus a 100 ohm 2 watt wire wound pot in each so you can balance or unbalance to suite your distortion nature like's.
Also in each add a 1 or 2 watt 1 ohm 1% resistor so that by placing a ohm meter set for DC across it you can directly measure the tubes current.
You could find a '470R' wire-wound resistor that measures 480R and put a 2k2 to 2k7 resistor in parallel with it on a switch
- RJ Guitars
Variable Output Bias Circuit
I used a big rheostat on one of my Rockster builds. IIRC correctly it was something like a 100 ohm 50 watt rheostat that I put in series with a big chassis mount resistor. This allowed me to test out a variety of output tubes and I eventually settled on KT-66's as my favorite tubes for the Rockster. You can find big rheostats pretty reasonable priced on eBay.
http://www.rjguitars.net
