I started actively working on and building tube amps just a year ago... You, guys, helped me so much. Even the suggestions you made that I did not respond directly, I read them and try to understand... After building the modified Princeton and Bassman ( with the voltage doubler and Diode rectifier), I want to try to combine the great AA864 circuit
...with the tube rectifier. I like that small sag that the tube does... Is it allowed to do so?
may be close to Vibrolux 6G11-a
[/img]
Trying to understand and learn through next project...
