The amp in question is a two channel 100 watter as seen here - http://ampgarage.com/forum/viewtopic.ph ... =crossline
I've installed both a Lar Mar and a crossline in the amp and have stuck with the crossline because it sounded fine.
The Marshall side doesn't need a MV, as it has it's own. The Express side though, as expected, is LOUD and needs tamed, but both styles of PI MVs really have no control until they were turned down to 1 or 2.
What is the simplest Pre PI MV I can add to just the Express channel?
One other thing I want to play with is, The express side has a Footswitchable tone stack lift. It is great but needs attenuated. Is there a way to knock off some volume when lifting the tone stack?
Thanks.
Adding MV to one channel of amp
