Here is my Kalamazoo 30w bass combo built in 1965 per schematic that was inside the amplifier.
Wanted to document in case anyone needs to build such an amp.
Kalamazoo 30w bass combo 1965
Re: Kalamazoo 30w bass combo 1965
Nice!
I have worked on a few of those and it's nice that for Bass usage they chose to fix bias it while Ampeg was still in Cathode bias output stage mode with the flip tops!
I usually make that first filter node cap for the plates a 80 mfd!
Recently got it back from a guitar store I was trying to sell it at but they said it was acting up so I need to see what is going on probably just a tube and I don't have any extra of these.
Hi Mark
Very tidy example. Interesting seeing the schematic - slight differences from the repro Bass 30 schemes I've seen on the net.
Be curious to know what sort of AC voltages you are getting at the PT secondaries (as well as the B+) if you have time.
(Maybe some of the problem is in those old(?) black sprague electrolytics in the bias supply?)
Cheers
Cheers
Pete,
I can write the voltages down sure no problem.
Pretty cool
Like a Williamson amp with tone controls....
TT
TT
I bet the amp looks more like this schematic...
http://el34world.com/charts/Schematics/ ... bass30.pdf
