1 ohm bias resistors. Needed?
pdf64
Re: 1 ohm bias resistors. Needed?
Post by pdf64 »
So, taking a TR AB763 as an example, and, in compliance with the policy to only use something 'designed for purpose' when a protective function has been identified as being potentially beneficial, fitting a dedicated fuse, we’re going to want -
a fuse on each HT winding phase of the PT
a fuse between rectifier output and reservoir cap
a fuse in series with the HT supply to the OT CT
a fuse in series with each screen grid resistor
and a fuse in series with each 6L6 cathode return to 0V. Comes to 12 fuses.
Looks like we’re going to need a bigger chassis for all the fuseholders!
Maybe consider a full on fuse panel :D
Whereas there’s a long history of 1W screen grid resistors blowing in response to a screen grid short, a somewhat shorter but a ‘seems to work’ evidence of ~1/2W 1 ohm MF cathode resistors blowing in response to some power valve failure modes, and the ‘but it works’ evidence of beefy high voltage diodes protecting the HT winding.
So that’s 10 fuses saved.
And surely everyone here has experienced the scenario of an actual, seemingly correctly specified fuse somehow hanging on and refusing to blow, despite it passing fault current that caused damage to the expensive thing that the fuse was supposed to be protecting.
I’ve too have had ~1/2W 1ohm MF cathode resistors that have blown in response to a 6L6 shorting.
I’ve also put F330mA cathode fuses in another 6L6 amp, only for a short that developed in one of the 6L6 to damage the OT primary winding, before the cathode or T500mA HT fuse (yes I like fuses, honest) managed to blow and save it.
BTW a fuse in series with the HT feed to the OT CT is a bad idea; if it blows, eg in response on one valve shorting, the remaining power valves will then draw a very high screen grid current, probably resulting further damage.
And dedicated cathode fuses are kinda pointless, as they only protect against a certain valve failure mode, and are of no benefit for the shorts that send HT current via the heater circuit. And we know that the latter failure mode is a fairly common one, from the regularity of amps that have blown heater balancing resistors turning up on the repair bench, right?
R.G.
Post by R.G. »
I'm reminded of the old quip - the race is not always to the swift, nor the contest to the strong, but that's the way to bet. :D
As I mentioned here and elsewhere, most considerations of fault protection are a question of objectives, balancing the cost of doing something intended to protect against an expected failure against the lower cost of hoping that everything will work out OK and any failures that don't can be just absorbed. The easiest and cheapest up front way to deal with expected fault conditions is to ignore them. This works GREAT as long as you're willing to bury the remains and get a new on if one of the disastrous faults happens. This is actually an economic decision. If you're willing to let a given amp die or pay for the repairs, no failure protection is needed at all. If you (or the owner of a valuable amp) really doesn't want to take a chance on having to replace it, some money spent on protection might make sense. A sense of practicality has to rule though, as you're trying to say, I think. The most certain way to never have an amp fail ever again is to buy another one and never turn this one on again at all. Most people would agree that this was too extreme a position.
Rather than simply saying that the cost of protection other than >relying< on parts not intended for that purpose, a detailed analysis would probably come up with some way to evaluate what failures are too costly, and are worth spending money to prevent, and what other failures are trivial and don't need protection money spent up front, accepting the cost of repairs.
Let's look at that list and do some evaluation of what's being protected and what's being left open to repair costs. A good start with that is to figure out what's most costly to repair. In a given tube amp, the most costly part is usually the power transformer. The OT is generally somewhat cheaper, unless there is some sense of it being vintage/original/solid gold and too valuable to take a chance on. Tubes are wear items; they die in the normal course of operation over time. Money spent on protecting tubes in a circuit that doesn't eat up every new tube had better be pretty minimal. Resistors and caps? Well, maybe the main filter caps, but that's getting well down the list of replacement cost compared to the magnetics. The choke might be in there, maybe not. So let's look at the list.
Probably worth a fuse. Those PTs are expensive!
Hmmm. What's this protecting? If it's the PT, better to just keep the two on the phases and skip the fuse. If it's the rectifier tube and/or filter caps, there is a real question whether to spend money on this fuse or just rely on the phase fuses. There are other ways to do this as well, not involving fuses.
Protecting the OT from overcurrents? Probably worth the money.
Is this protecting the PT, OT, rectifiers, filter caps, or the tubes? If the tubes are "magic vintage" tubes, maaaaaybe? Probably not. Unless the tubes and screen resistors are too valuable to let fail, probably not. But you could if you just wanted to, I guess. If it's to prevent a runaway tube from killing the OT, a fuse in the OT CT is better.
The test again: what's that protection for? If you have the CT fuse for the OT's protection, you don't need a fuse per tube; tube shorts are already covered.
I count three fuses there. A fuse in the heater winding, two if it's got a hard CT, would probably do a good job of keeping the PT safe from faults outside the PT itself. So maybe five.
Yeah, it's a lot. But there are side-by-side phenolic blocks of five fuses available.
Taking on a couple of the precepts:
Using something designed for purpose makes sense in any situation where you want control of what happens, not wishful thinking or hoping for lucky coincidences. And, as mentioned above, whenever "a protective function has been identified as potentially beneficial" isn't always the time to spend money, time and space on protection. Sometimes the sensible thing to do is to self-insure and count on simply doing the repairs. My curmudgeonly view is that if it's worth spending thought, time and money on protecting, (and even then, usually protecting against collateral/chain failures) it's worth doing it right.
As above, what is the screen grid resistor opening protecting? If it's the OT, a fuse in the CT is a better place to spend your effort. The tube is already dead. If it's the PT, the phase fuses are a better place to spend your effort. Then there's the question of coverage. Will the screen grid resistor open in time to protect what it's supposed to? What if the last ones you got are just extra tough and don't give up in time? That long history is a collection of anecdotes. Sure, it happens. But stories don't get passed around about the ones that didn't protect by opening. If you're spending time protecting things, it's worth some thought about whether it will work correctly in which cases, what the effort is being spent for, and whether there's another way that provides more fault coverage.
Same comments. It's good to ask (1) what am I protecting by doing this and (2) is there a better, more comprehensive and predictable way.
Sounds good - I've always thought that adding higher voltage, higher current solid state diodes in series with the HT winding made a lot of sense.
That gets me back to that "but that's the way to bet" thing. Which is more likely to happen - a properly specified fuse not blowing or a resistor with no specification on how it behaves when it gets how much overheated opening at just the right time?
That can happen. But fault protection is a game of statistics, as you may have picked out of my comments. It's picking out "that's the way to bet", and deciding where to spend your time, thought, and money. There are anecdotes and counter-examples to nearly every principle. But one counterexample doesn't mean you should stop evaluating what's most likely to happen.
Goes back to that "what are you protecting" thing. I agree that high screen currents can cause further damage. The question is damage to what, and what's the cost of protecting what's likely to die balanced against the cost of repairs if you don't protect, spread out by the likelihood that the probably further damage occurs.
This is worth digging down into the consequential failures a bit. The OT CT fuse opens. The screen grids then draw a lot of current. First up failure is likely to be the tubes with the high screen grid currents. A decision is required - do you want to spend money, parts and time protecting the tubes?
Maybe. If the OT CT fuse has opened, the likeliest cause was one of your tubes failing shorted. Possibly a wire touched the chassis, possibly the choke shorted internally. There is a string of other lower probability thing. But likeliest, one tube is already dead. That matched pair or matched quad is now unmatched, and that can't be repaired other than by replacing all of them. So it may well be reasonable to protect the remaining tubes, especially if you individually bias them to save on matching. The failure mode on the tubes is likeliest to be melting screen grids from the high screen current. This might be a place to do one of the following:
> take it on the chin and replace the tubes
> hope and pray that the small-wattage screen resistors you decided to rely on happen to open in time
> run all of the screen grid resistors to a fuse (Yikes! A fuse!) to interrupt the screen current
> use some other electronic means to shut down the B+; this is a favorite of mine, but outside the scope of this post
It isn't going to kill the OT, that fuse has already opened. It isn't going to kill the PT, there are fuses for that. It isn't going to kill the rectifiers; they're specified to take the current up til the PT fuse opens. It probably won't discharge the filter caps fast enough to damage them.
What else is likely to be damaged? I'm sure I'm missing something. Help me here.
I agree. I'd do that protection another way. Again, the questions are what is being protected? In this case, it's probably the PT and rectifiers. A PT with phase fuses won't die from that. A rectifier tube might get hurt. But with auxiliary high voltage/current solid state rectifiers, the PT again won't take the hit. Filter caps will probably live. The heater being shorted to probably won't notice the extra current, and a cautious person might have heater winding fuses in any case. The same issues arise: what is already dead, what is being protected, and what is the cost and practicality of the protection weighed against the percentage likelihood of the failure happening versus the cost of repair.
Got any numbers on that? What's the actual statistical likelihood of any given tube failing shorted from HT to heater? It's noticeable when it happens, OK, but what are the real chances? Numbers matter.
pdf64
Post by pdf64 »
Many thanks for the amazing response - dunno how you even typed up all that so fast, nevermind formulate it :o
R.G. wrote: Fri Jan 08, 2021 11:52 pm...a fuse on each HT winding phase of the PT
Sounds good - I've always thought that adding higher voltage, higher current solid state diodes in series with the HT winding made a lot of sense...
With most bi-phase HT windings, eg AA1164 Princeton or 1987 Marshall, I prefer a fuse on the CT to 0V return and an additional pair of beefy safety rectifier diodes; between them, they should cover all the generic HT failure modes. But with a bias tap on the winding, unfortunately that's not feasible.
A problem with the 'fuse per phase' approach is that if the fuse on one phase blew spuriously, additional strain may be put on to the remaining phase, which seems something of a drawback. I've not verified that actually happens though.
R.G. wrote: Fri Jan 08, 2021 11:52 pm...a fuse between rectifier output and reservoir cap
Hmmm. What's this protecting? If it's the PT, better to just keep the two on the phases and skip the fuse. If it's the rectifier tube and/or filter caps, there is a real question whether to spend money on this fuse or just rely on the phase fuses...
From the above, for the TR AB762 and other such Fender type amps, I use the beefy diodes with the HT fuse on the rectifier output.
R.G. wrote: Fri Jan 08, 2021 11:52 pm...a fuse in series with each screen grid resistor
Is this protecting the PT, OT, rectifiers, filter caps, or the tubes?...
The HT choke also seems likely to be stressed?
But my thinking is that a screen grid short may be swiftly followed by the anode drawing fault current, due to rapid heating of the valve's internal's resulting in secondary emission or something. So I suppose it's all the iron and associated stuff in that HT current path that's at risk.
My thinking is that putting the 'protective function' as close as feasible to the actual fault offers the greatest degree of discrimination to the protective device, ie the biggest ratio between fault current and non-fault max loading current. Hence that offers the lowest likelihood of spurious fusing and the best chance of it opening in response to an actual fault. By putting the supply to all screen grids via a common fuse, the ratio between '1 failing screen grid on whilst the other 3 are idling', and 'normal max loading' won't be as large.
Similarly for the cathode's 'protective function'.
Additionally, the amp caries on working, may even make it through the gig (user may not even notice :D ), and fault finding becomes a lot faster and more accurate, with a lower likelihood of mis-diagnosis.
What else is likely to be damaged? I'm sure I'm missing something. Help me here...
It seems a reasonable likelihood that if the OT CT fuse blows (perhaps even spuriously), due to the resulting excessive high screen grid current, all 4 power valves and perhaps the choke may be at risk of ending up as collateral damage? Even if one had failed, that still leaves a matched pair and a 'known good' spare left. So it seems worth doing something to mitigate for that, so if fusing the OT CT, the screen grids should also surely have dedicated protection.
It would be great if 'made for purpose' fusible resistors were readily available in 1ohm and the typical screen grid values, eg
https://www.mouser.co.uk/datasheet/2/42 ... 761886.pdf
https://www.mouser.co.uk/datasheet/2/30 ... 228678.pdf
https://www.mouser.co.uk/datasheet/2/42 ... 762700.pdf
Yay, look what I found -
https://www.mouser.co.uk/ProductDetail/ ... Uw6Q%3D%3D
https://www.mouser.co.uk/ProductDetail/ ... z6l1Sac%3D
Apart from cost, any downside to those?
Of course, but c'mon, there can't be many people with such data, and unfortunately I'm not amongst them :D
R.G.
Post by R.G. »
pdf64 wrote: Thu Jan 14, 2021 8:03 pm A problem with the 'fuse per phase' approach is that if the fuse on one phase blew spuriously, additional strain may be put on to the remaining phase, which seems something of a drawback. I've not verified that actually happens though.
The thing about conventional iron and copper PTs is that their death is largely thermal. If you pick the correct value fuse for the two halves of a B+ winding, selecting it for the current which will cause it to overheat, melt the insulation, and have shorts between turns, then a spurious blow on one half causes no further harm to the still-working half. If it's fused at a safe current level, it may blow, may not, but the additional "strain" is still caught by a protective fuse. What happens in losing one half of the B+ winding is that the remaining winding becomes a half-wave rectified power supply, and so the ripple at least doubles. However, half of the B+ secondary (the one with the open fuse) is now generating no heat, so the still-working one may or may not get hotter. Probably some. But still, a proper value fuse protects the remaining winding.
That's fine, but it sacrifices protecting the PT from a rectifier short. I would still protect the PT first.
Yep. Protect the iron. The choke is a question. I have pestered my amp-tech friend, who is in the trenches of amp repair in Central Texas. He's found exactly one choke which shorted to its core. Transformer iron and copper are >very< tough. What dies is the insulation. Overcurrents that don't degrade the insulation inside doesn't cause any lasting stress. It's important to remember where the current comes from, too. The filter caps can only supply a few seconds of high current if the PT isn't constantly feeding them current, so it you're current limiting the PT, you're also ultimately limiting the choke and the OT. It just gets trickier to pick the right fuses for the PT that will also protect the choke. Or, put another way, is the choke rated for more current than can be shoveled through it by a screen grid short. The screen grids do (er, usually) have resistors in series, so you can at least put a number to the current that will flow when a screen shorts to whatever.
I realize I haven't said this explicitly, probably. If you have a fault, currents will run wild for a while. But if the current is interrupted from the PT, that running wild will be short lived while the filter caps empty. So a lot of my ideas on protection involve sensing [whatever] and then telling a big, fat, 1kV/20A/$2.00 MOSFET to stop conducting, which it does in a few microseconds. So is you have a tube gone mad, or screen short, and can somehow tell when that happens, you can stop any further damage by shutting off the MOSFET.
This gets into areas where philosophy can't help much any more, you need numbers. It does seem like you need good discrimination, and depending on the numbers, it >might< be that the ratio of one fault to four normals is too small to tell. And then, fuses are clumsy tools. They're hard to specify well, and they have that annoying time lag, I2T energy ratings to calculate, and so on. My preferred method is not to use a fuse as a discriminator. Use a current sensor with some chance of better than one in ten discrimination, the have your circuit decide what to do.
Spurious fusing comes up in any discussion of fuses in guitar amps. It happens, but is rare with quality suppliers, more common with the cheapest fuses you can get, just like with everything else. My approach? If a player (or his manager, or tech) isn't carrying spare fuses in his gear bag, he may not be teachable.
That brings up an interesting point. Does the owner >want< the amp to keep working if it's got situations inside which blow fuses? Maybe. Maybe not. There is an alternate stream of fault protection design that tries to keep the equipment running even in the face of failures. Fault tolerant design is something that I was brushed against a couple of times. You think designing single-fault protection circuits is tough? :lol: Fault tolerant designs can easily be twice as expensive as a non-protected design, in which case a gig player probably ought to just buy a second amp.
Having an amp keep on working is a mixed blessing. It may or may not be a good thing.
This continues down the logic path of whether the amp should work in a degraded condition, or protect itself from possible further damage. There are good arguments both ways, and ultimately, it depends on the owner's informed preferences. The first question on collateral damage is at least open to calculating what happens. If the OT CT fuse blows, then only the screens are conducting. The screen current goes up, and is limited to the screen grid's "plate resistance" and the screen resistor from the screen supply to the cathode. I don't have a handy number for that would be, but I'm pretty sure there is one. Some calculations could tell you whether the choke and other output tubes are at risk. More analysis needed.
And it just struck me - I probably would not put a single OT CT fuse in as protection. For protecting transformers, you have to protect the individual windings, so you need one fuse per primary half to protect the OT. This obviously goes in series with the plate(s) per side.
Only the usual problems with fuses - getting them specified well to guarantee holding max normal current while ensuring opening on damaging overcurrents. I wonder why everyone doesn't use these... :)
rooster
Post by rooster »
RG, a great read there! Thank you.
Phil_S
Post by Phil_S »
rooster wrote: Tue Jan 10, 2023 12:49 am I see this once in a while, not just on TAG, where someone is talking about the primary side of the OT (the portion of the OT with a Center Tap and it's two legs attached to either power tubes?), but then calls it the 'secondary'. This might confuse a few ppl that come here to learn. Just sayin.
You're sayin' right. I "misspoke." I did mean primary. Thanks for catching it. I edited the original statement.
rooster
Post by rooster »
No worries, Phil. I'll delete my post.
