Wrong. I simply asked whether pulling the tubes before taking those measurements would be ok.pompeiisneaks wrote: ↑Tue May 29, 2018 3:17 pmYou seem to be ignoring the requests of one of the best amp troubleshooters I've ever worked with, do what sluckey asked and you won't be far from a solution. IMO anyway.tyler8611 wrote: ↑Tue May 29, 2018 3:15 pm Ok so I resoldered the tail resistor ground- no change. Still motorboating. Mind you, I have a 100k/.047 across the standby, so that's why it's trickling in enough to be audible. I've used that method on all my standby switches with no pops and no problems. I double checked to make sure this one is wired and soldered correctly, so that's not an issue.
My best guess is bad filter caps, failing PT, or bad power tubes which I highly doubt since they're fairly new JJs and I tried them before in a tweed deluxe. They always light up normally, no redplating, etc.
Should I remove the tubes now and measure to see what's going on?
Deluxe Reverb voltages
Re: Deluxe Reverb voltages
Thought I had already mentioned, but the resistance from pin 8 to ground is 1.5 ohms. They're vishay dale resistors.
well shoot, I'll just shut up then and not try to help, it's obvious from your reply you're not wanting any from me.
Pin 8 to chassis- 1.5 ohms
With only the rectifier installed:
Pin 3 to chassis: 460v both
Pin 4 to chassis: 460v both
Pin 5 to chassis: -15v both
Voltage readings with no tubes installed are meaningless. Except for that pin 5 voltage. Better fix that before you plug in the 6V6s.
Gotcha, I'll put em back in. Should the pin 5 voltage be more negative? And would involve changing the bias tail resistor or simply adjusting the pot? It was all the way down (as looking from underneath) when I measured.
Per the schematic on a fender deluxe reverb aa763 (most will be within that range for 6V6) it calls for -35V so your bias pot should be able to dial it more negative than that as well. Say -40 or more. Then you can adjust according to taste after you measure and get the exact plate current. -15 is way too low of negative voltage and you're going to chew up tubes running that hot.
Sorry I couldn't help responding as that's something sluckey already stated setting this to max negative was important. You said you adjusted it but never reported what it actuall was. If you expect people to help, try and give them as much information as possible. I know from personal experience, sluckey is patient, but I led him on a few good goose chases because I wouldn't give him exactly what he was looking for. As sluckey reported, I'd not put those tubes back in until you can get the negative bias in a healthy range.
I think your involvement here is counterproductive.pompeiisneaks wrote: ↑Tue May 29, 2018 5:29 pm Per the schematic on a fender deluxe reverb aa763 (most will be within that range for 6V6) it calls for -35V so your bias pot should be able to dial it more negative than that as well. Say -40 or more. Then you can adjust according to taste after you measure and get the exact plate current. -15 is way too low of negative voltage and you're going to chew up tubes running that hot.
This is so out of line, Tyler. Phil is a moderator here and is trying to help. Why are you asking for help and then refusing it when it's offered?tyler8611 wrote: ↑Tue May 29, 2018 5:50 pmI think your involvement here is counterproductive.pompeiisneaks wrote: ↑Tue May 29, 2018 5:29 pm Per the schematic on a fender deluxe reverb aa763 (most will be within that range for 6V6) it calls for -35V so your bias pot should be able to dial it more negative than that as well. Say -40 or more. Then you can adjust according to taste after you measure and get the exact plate current. -15 is way too low of negative voltage and you're going to chew up tubes running that hot.
"Genius manifests itself. You got a hammer. You either build a Cathedral or you build a shithouse." - Carl Schroeder
So you're saying because I was right and you didn't want to listen to me, I'm the one with the problem? Seems definitely counterproductive. Usually being rude and the like to forum members increases their desire to help right? I try to do my best to help, and you're being rude to me because of it. Not only that, but one the most knowledgeable people that I likely know of on this and other forums is offering you help and you're still not listening to his suggestions either. Must be my problem.tyler8611 wrote: ↑Tue May 29, 2018 5:50 pmI think your involvement here is counterproductive.pompeiisneaks wrote: ↑Tue May 29, 2018 5:29 pm Per the schematic on a fender deluxe reverb aa763 (most will be within that range for 6V6) it calls for -35V so your bias pot should be able to dial it more negative than that as well. Say -40 or more. Then you can adjust according to taste after you measure and get the exact plate current. -15 is way too low of negative voltage and you're going to chew up tubes running that hot.
Adjusted the bias pot back to halfway and here's what I have:
Pin 8 to chassis: 1.5 ohms
Pin 3 to chassis: 153v both
Pin 4 to chassis: 153v both
Pin 5 to chassis: -32v
Well it isn't the tubes. Tried out another pair. Funny thing is the plate and screen measurements are good while the amp is on standby. Turn it on and they drop down low again.
The 1.5R resistor is probably a 1R resistor with the meter leads adding 0.5R of measurement. What is the mV (DC) across this resistor? (We need to know this the calculate the tube current)
