There are many “ magic “ parts used consistently by builders who select their preference. I haven’t seen a bludotone without a koa Speer…Friedman likes sozo blue caps …germino uses sozo yellow consistently …and everyone seems to use orange drops with very consistent good resultsR.G. wrote: ↑Fri Feb 24, 2023 3:45 am
Here's one other thought for you. If there was a magic resistor, or cap, or whatever, that made amps sound GREAT, the folks with lots of money at risk making entire amps would have long ago figured out, even if crudely, what that different part is/was, and be using only that in their amps.
These all have their “magic” in their given context. Germino definitely is its own thing and different from Marshall , yet they are the same schematic.
I don’t really understand why we keep referring to a singular “ magic “ component . My point is that all parts , at least in my experience , have a unique tonal effect for any number of reasons, known and unknown.
I understand the response is designed to be inclusive of the larger audience reading….R.G. wrote: ↑Fri Feb 24, 2023 3:45 am
Ok. Here's how to do that.
Get a disinterested party to run a blind ABX test with you as the subject. If swapping carefully value matched parts in such a blind ABX test shows that you personally can reliably do better than guessing at identifying a part change, and for extra points identify that some brand/material/age of parts is always better, great! You have proven that you personally can identify which parts are better to your hearing. If you prove that you in fact can't do better than random chance, you have actually proved something valuable; you've proved that single part variations do not get detected per se by your hearing, and you can quit searching for mythical parts to make the amps better.
This gets rapidly more complicated if you enlarge the range to "does one amplifier sound better with X parts or Y parts?" or "must I just use X material resistors/caps/wire/solder to get a good sounding amp?"
…but with all of my testimony…and other’s… in this thread alone … with hundreds upon hundreds of hours of obsessive nitpicking testing and comparing of components ……do you really think I can dismiss all of that by finding someone approved by you to put my hearing to the test?
As if I am guaranteed to discover I can’t hear or remember accurately enough to maintain my convictions?
please excuse me if I have my reservations. I don’t fault you for having your own about any of my claims, as I can’t reasonably expect anyone to take my word for anything, but I can only insist that there hasn’t been enough evidence thus far for me to “quit searching”.
I said it once already : what matters most for the player is how inspired one becomes when they play . Is there a tool to measure that? In the right context some might argue how much money they would spend lol .
I have discussed in different threads about swapping entire sets of resistors , from one brand to the next , within an amplifier . the differences are evidently large enough to inevitably determine whether a professional player is begging to buy it or not … I am not talking about amateurs practicing for their YouTube recitals … but ironically these changes are all easily detectable by non musicians alike when interviewed …something like that is not a small difference .
It’s also the difference between my wife closing the door to my shop or not lol
I repaired/reconed speakers professionally for about a decade . I stopped because the glue fumes were too toxic , even with proper ventilation and protection , it was just too much for me . Made me grumpy and irritable .R.G. wrote: ↑Fri Feb 24, 2023 3:45 am
I do believe in magic circuits, and carefully setting gains, noise budgets, frequency rolloffs and the like. And in carefully, carefully, carefully characterizing speakers. It's simply amazing how much difference a different speaker can make to an amp's sound, even one of the same brand and manufacturing date. Speakers are acoustic creators, and have their own voices. This can, and has been measured. I find it strange to find yet another internet discussion on whether carbon comp, carbon film, whatever, has a huge effect on tone, and so little discussion of the known huge effect of speakers and cabs. But that's just me.
Nasty.
I digress, I have tested repaired and installed countless speakers. To emphasize the point you made , practically no two speakers are exact. Some companies are far more consistent, and amazingly so. A simple tap test with your finger on a speaker cone can let you know plenty on this factor . As correct as you are about speakers , in my experience it’s certainly not enough to negate the effects of tonal effects varying electronic components within the amplifier .
I make sure I use the same guitar and speaker combination for any comparison , but I find the instrument that works best for distinguishing nuance is a Stratocaster with single coils into an overdriven preamp . Overdrive highlights ugly .
